KZ900 with front fork air fitting ?
  • Russ Jackson
  • Russ Jackson's Avatar Topic Author
12 Jul 2015 12:16
#680532
Out at Mid Ohio this weekend I saw a 1976 KZ900 with an air fitting in the headlight bucket. It was for filling the front forks. Is anyone familiar with this and was it a stock option? It said 25lbs Min and 50lbs Max.
1976 KZ 900 B1 29 smoothbores, Kerker, Lester Mags
2008 Kawasaki Concours 14 abs
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: KZ900 with front fork air fitting ?
12 Jul 2015 12:23
#680533
Not stock and pretty much useless.
  • missionkz
  • missionkz's Avatar
12 Jul 2015 12:59
#680546
That was a fad that went nowhere..... All my modern dirt bikes had schrader valves.
Wait.... didn't I see those on somebody's fork top bolts here....?
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
12 Jul 2015 13:01
#680547
If you pump 25-50 PSI into the stock KZ900 forks you will blow the fork seals. Ed
  • Dan-kz
  • Dan-kz's Avatar
15 Jul 2015 18:35
#681061
1981 kz750E2 has air. Valves at top of forks. I think the max air pressure. Is 26psi but not completely sure.
  • TexasKZ
  • TexasKZ's Avatar
  • Away
15 Jul 2015 19:13
#681071
I seem to remember that my 750 LTD owners manual called for 5-8 psi or so.
  • SWest
  • SWest's Avatar
  • 10 22 2014
15 Jul 2015 20:21
#681079
missionkz wrote: That was a fad that went nowhere..... All my modern dirt bikes had schrader valves.
Yeah, I got em. Didn't help. Had a crossover too. More than 10 LBS and it rode like a rock. Too hard to just get 5/8 in them. I thought about having a ballast can but where to put it? I bought progressive springs and the valves are there to remind me of something that didn't work. :pinch:
  • Dan-kz
  • Dan-kz's Avatar
18 Jul 2015 18:26
#681561
Could progressive springs go in my 1981kz 750e2 and anyone know how to change the fork seals?
  • TexasKZ
  • TexasKZ's Avatar
  • Away
18 Jul 2015 18:40
#681563
Progressive Suspension has a fitment chart on its website. I bet Sonic and Traxxion Dynamics do too.
The factory service manual has a pretty detailed explanation of the seal change procedure. It is not complicated, but some models have little quirks. An impact wrench will be a big help.
The following user(s) said Thank You: Dan-kz
  • SWest
  • SWest's Avatar
  • 10 22 2014
18 Jul 2015 18:48
#681566
I always wanted them but the price was through the roof. That's when the bikes were new and everyone and his dog were trying to cash in on parts. Lots of scams and performance improvements that got you nowhere. There was a guy trying to sell a $2 bracket for $100+ because it would fit a Z!. :angry: Dog vomit. :sick:
