How to determine year, and decode 12 digit VIN?
  • yahodahan
  • yahodahan's Avatar Topic Author
09 Jul 2015 04:22
#680129
Hi all, thanks for any help! I just purchased a KZ550G/550GT, and need some parts. However, I cannot decipher the actual year. The VIN has only 12 digits, and the rims could be showing either "86" or "98", and of course those might just be swapped...the logbook shows 2000, for further confusion. Any help would be much appreciated!
Here is the full VIN, in case it's of use: kz550g-020359
Re: How to determine year, and decode 12 digit VIN?
09 Jul 2015 06:04 - 09 Jul 2015 14:26
#680139
[strike]I can't give an exact date because the G wasn't a US model, but from what I've read the KZ550-G was in production from 1983 - 1986. Ed[/strike]
I stand corrected. It is clear that Kawasaki made the G model much longer than I thought. Ed
Last edit: 09 Jul 2015 14:26 by 650ed.
  • martin_csr
  • martin_csr's Avatar
09 Jul 2015 06:17
#680144
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
09 Jul 2015 12:01 - 09 Jul 2015 12:01
#680192
yahodahan wrote: Here is the full VIN, in case it's of use: kz550g-020359
Is it 002359?
The link Martin posted doesn't show that high production.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
Last edit: 09 Jul 2015 12:01 by Kidkawie.
  • martin_csr
09 Jul 2015 13:47 - 10 Jul 2015 07:33
#680205
Complete production numbers aren't provided. It could be a G8 or G9. ??? From his other topic the bike is red, so the color would be correct for one of those.
Last edit: 10 Jul 2015 07:33 by martin_csr.
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
10 Jul 2015 05:01 - 10 Jul 2015 05:02
#680281
A pic of the bike would help. Also, find the FSM for the bike and look at production numbers on the back cover. Find what model your frame number falls into, that's the year.
1975 Z1 900
2004 KX125
Last edit: 10 Jul 2015 05:02 by Kidkawie.
  • martin_csr
10 Jul 2015 07:50 - 10 Jul 2015 07:55
#680302
cmsnl.com --- Z550-G9 .
The G9 is listed as a 93 model, but there is a model identification schematic in the diagrams that lists a 1994 Z550-G9. The schematic shows the beginning frame & engine numbers.
tagsz GT550 Z550-G9 GT 550 550G Z550-G1
Last edit: 10 Jul 2015 07:55 by martin_csr.
