Front fork upgrade advice
  • sled
  • sled's Avatar Topic Author
29 Jun 2015 05:06
#678683
G'day I have a set of 2000 r6 forks they measure around 760 from centre axel to top of the tube I'm thinking they are probably not a good option for my 76,kz900
Any advice from experienced fork swappers ?
Any help is appreciated
Cheers Jason
  • davido
  • davido's Avatar
Re: Front fork upgrade advice
29 Jun 2015 05:22
#678685
I put a complete ZX9R front end on my 1000 . Looks fantastic and my fingers are crossed that therell be enough ground clearence once the engine is in and the exhaust is on.
Oh how Ill laugh if theres not!!!!!!
You could probably figure it out pretty close with a measuring tape and pencil and paper. (If the 900 is still complete )At least to get a rough idea. Or like me,you could strip the bike first before you decide on a conversion,that way you cant measure anything and can spend countless time,energy and money on the build whilst all the time,not knowing if its going to work or if the whole thing is going to scrape along the ground. At least you wont have to worry about a centerstand.
Good luck
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
  • monkeydoodle
  • monkeydoodle's Avatar
29 Jun 2015 13:33
#678736
I'm using a ZX7R front on mine which is 30" in length - I think the Zx9R is 27" after reading shed loads of info since deciding on an USD front for my 750
Custom Harley Chop
2004 Fazer 1000 with Ivans Full Monty kit
1980 Z750E (half way being re-born into a mix breed something)
  • davido
  • davido's Avatar
29 Jun 2015 13:40
#678737
I did have a link to a site that gave fork lengths somewhere but of course,I cant find it.I did find this though if it helps
www.caferacer.net/forum/project-builds/1...onversion-chart.html
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
  • sled
29 Jun 2015 15:08
#678751
davido wrote: I put a complete ZX9R front end on my 1000 . Looks fantastic and my fingers are crossed that therell be enough ground clearence once the engine is in and the exhaust is on.
Good luck
Thanks for the reply I was having a look at your build thread and you mentioned the zx9r forks measured 77cm the r6 forks measure 76 top of fork to centre of axle unloaded where did you take the measurements from. I'm a little concerned about exhaust clearance
Cheers for the response
  • davido
  • davido's Avatar
30 Jun 2015 08:11
#678831
It would have been from the top of fork to the center of the axle,like you say.I can check again. I think the big difference twixt my bike and yours is that mine is/was a cruiser. So it had quite long forks ,a leading axle mount and a huge front wheel (19inch,I think).
I went from that to a 17inch wheel on a set of shorter,sportier forks. It was a concern for quite a while then I just fogot about it and got on with the build.Im not going to know for sure until the engine is in and the exhaust is on, Hopefully that will be happening in a couple of weeks.
Your bike ,I imagine is more of a roadster to begin with and like I said before,you should make some drawings with good measurements to get an Idea. An important one (one which I forgot to get) was from the top of the triple tree bolt straight plum down to the ground twixt the engine and the front wheel. If your new setup brings you close to that measurement,then you should be good,regardless of what wheel or fork setup you have.
Ill measure up what I have and get back to you.
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
  • davido
  • davido's Avatar
30 Jun 2015 09:42
#678841
OK, ZX9R forks are 77.5cm from center of axle to top of fork tube (bottom of fork cap) and the CSR1000 is 85cm.
So 75mm difference in just the forks.
Then theres the front wheel.From 19inch down to 17inch. (Not sure what the aspect ratios on the tyres are) ,thats another 25 mm.
So a total front end drop of 10cm +- for me!
The back end also moves up slightly.Going from a 16 inch wheel up to a 17 inch. But the orginal tyre was quite tall (a bigger aspect ratio or a smaller one? Im not sure which way round it goes) so I dont think theres going to be a huge difference there.
Then theres the lowest point of the bike,which,I think would be the bottom of the exhaust downpipes. They sit a bit further back from the front end of course so they wont drop the full 10cm. How far will they drop??????????????? Thats the question!!!!!!!!
Dont know if this helps you at all but its good to go through it.
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
