Frame welding question
- davido
21 Jun 2015 01:46
Ive had at least 3 different welders have a go at different bits on my frame. (1981CSR1000) Theyve all had the same problems. (very thin steel).
I did a welding course this weekend and brought the frame along. The instructor also had the same difficulties.
Is this an inherent problem with old kawasaki/japanese bikes or is it just my frame?
What is the best method for welding these frames? Mig,Mag,Tig,Tinkywinky,Dipsy,Lala,Po ???
Are other people struggling when welding their frames or is it Just me?
Any help/advise appreciated.
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
- monkeydoodle
Re: Frame welding question
21 Jun 2015 03:48
Hello buddy, not too sure about your frame specifically, I think you have seen mine in the photos, I found with my frame that on some of the welds there were signs of porosity but when dressed away there were also signs of penetration. I have done some good bits of welding on my frame and had my plant up quite high and never had an issue. I'm a welder by trade but in no way and expert in metal - but for what it's worth when I cut up my frame rails and removed brackets etc the wall thickness was absolutely fine and as previously stated apart from some very ugly welds done at source ( penetration being more important than aesthetics) the frame was fine to work with.
Custom Harley Chop
2004 Fazer 1000 with Ivans Full Monty kit
1980 Z750E (half way being re-born into a mix breed something)
- Nebr_Rex
21 Jun 2015 04:46
Tig will be your best choice. J models have thinner wall tubing than earlier KZs.
Surface preparation and low heat are needed. To much heat will draw out any contamination
on the inside wall of the tube. Also, most of the tubing will be sealed up. When
heated up by welding the pressure will rise inside increasing the chance of blowing a hole.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- PLUMMEN
21 Jun 2015 05:44
Ive stick welded plenty of z1/kz frames without a problem,never welded on a j frame that I can remember.
21 Jun 2015 07:31
Plus 1 on TIG
More control over the welding process .
Just my 2cts
Just my 2cts
- Shdwdrgn
24 Jun 2015 13:16
Some advice given to me when I was working on my frame... Take some extra (similar) tubing and slit it up one side. You want to slide it inside your frame so it straddles across the weld joint. The slit allows the tubing to expand so it tightly fills the area inside the frame, and the extra material gives you a lot more meat to weld, plus it holds your frame pieces aligned while welding.
1981 KZ1000-JK1
She's a beautiful mess, and I've made her all mine
- davido
24 Jun 2015 14:08
Good idea for joining tubing,shdwdrgn,but my problems are just from welding up holes and putting on mounting brackets and such.Its nothing traumatic.I think the pressure building up inside makes sense and the fact that j models use thinner steel than earlier versions makes me feel a bit better. I was worrying that I could have a frame thats rotten inside and all the work/money/time etc Im putting into this build could go down the toilet (or across the tarmac!).
Ive got 2 more tabs to weld on and thats it. Ill have another go with the tig.
Cant wait for it to be done so I can start on the paint.
Thanks for the input
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
