sprocket lock washer
  • ThatGPzGuy
  • ThatGPzGuy's Avatar Topic Author
25 May 2015 08:01
#673620
Hey I bought this lock washer from Z1 for my GPz. It is replacing the type where you bend down one edge against the nut.
How is this installed? Concave side facing the sprocket or facing the nut? Don't want the front sprocket flying off. That would suck.
www.z1enterprises.com/ItemDetails.aspx?i...line&item=92200-1065
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
  • Tyrell Corp
  • Tyrell Corp's Avatar
Re: sprocket lock washer
25 May 2015 08:43 - 25 May 2015 08:53
#673626
Looks like the older type, later GPz had a revised sprocket locking part: 92022-1351
Attachment abs3.png not found
There is another bits that goes with it, the part is discontinued now.
Attachment abs2.png not found
EDIT opps sorry it a 750, ignore the above post. :blush:
I'll leave it here as it is worth knowing about, it was revised for a reason due to failures of the earlier design. Mods feel free to delete this.
Last edit: 25 May 2015 08:53 by Tyrell Corp.
  • JR
  • JR's Avatar
25 May 2015 10:05 - 25 May 2015 10:06
#673633
ThatGPzGuy wrote: Hey I bought this lock washer from Z1 for my GPz. It is replacing the type where you bend down one edge against the nut.
The washer is saucer shaped. Flat side (bottom of the saucer) against the sprocket with the lip facing out. That way you torque to spec, slip a screwdriver tip under the lip and tap with a hammer to bend the lip against the side of the nut..
at least that's the way my old one was and that's the way I did it with the new one. I used that exact same washer from Z1E
Last edit: 25 May 2015 10:06 by JR.
  • KZB2 650
  • KZB2 650's Avatar
25 May 2015 13:57
#673673
I'm surprised they have this listed as working for the KZ650B since I have one and asked about it....... they told me it won't work as the sprocket fits exactly flush with the splines (and does) so it will not hook on the shaft splines so it does no good when you bend it over the nut..... not sure on the GPZ.
I went with a sun sprocket with the standard retaining hole and went with the reg lock washer with the tab that fits in the hole and then bending it over on the nut.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
  • JR
  • JR's Avatar
25 May 2015 14:17
#673675
I'm assuming the OPs GPz 750 is the same as mine. The splines come through both the sprocket and the lock waske.r The nut has a recess in the sprocket side that go around the splines. I probably have my old nut around somewhere and can take a pic.
If the nut is just plain flat with no recess on one side then its the flush type and requires a differnt way to lock. I just figured this out recently from a similar thread here
  • ThatGPzGuy
25 May 2015 17:16
#673706
Yes it is a GPz750 with the stock nut. I installed it today and bent one of the lips over the flat of the nut.
Thanks everyone. I'll probably check it after a few miles to be on the safe side.
Jim
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
