Rear peg mounts repair
  • spdygon
  • spdygon's Avatar Topic Author
24 May 2015 08:10
#673472
Someone before me drilled out the rear peg mounts...both sides.
Need ideas for repair.
1978 Kz1000 Z1R. 10K Miles1
1978 kz1000 z1r 27k miles
1976 Kz900A4 (Red)21K miles
1976 Kz900A4 ( Red)7500 miles
1974 Z1 900 project
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Rear peg mounts repair
24 May 2015 08:26
#673475
He drilled out the threads? Not much room left. DAMN, that's another reason PO's suck.
  • jakedude
  • jakedude's Avatar
24 May 2015 09:38
#673487
1) find some rear pegs with a long enough threaded shaft so you can bolt them on. You may need to include a bushing to match the peg shaft diameter to the hole.
2) Fill the hole with JB-Weld and then drill and tap the JB-weld. The folks from JB-Weld say you can do this. I don't know how well this would work however considering the load bearing of a passenger.
3) If the current frame hole is really big compared to the the pegs you want to thread in to the hole, perhaps you could JB-Weld in a threaded bushing. Just make sure you plug the threaded bushing hole with wax or soap before you start mixing the JB-Weld,
Nothing lasts, nothing is finished, and nothing is perfect.
  • SWest
  • SWest's Avatar
  • 10 22 2014
24 May 2015 09:52
#673489
The folks a JB Weld say a lot of things. I wouldn't trust it in this situation. I'd rather fill the holes by welding or brazing, then tapping them.
  • floivanus
  • floivanus's Avatar
24 May 2015 10:23
#673498
Weld shut, face it with a grinder and drill/tap a new hole.
Or your ither best choice is to cut those off and grab a set off a spare frame and buzz them on
Past; 78 kz1000, 83 kz550
Andrew
  • spdygon
24 May 2015 13:02
#673520
Hate to cut them off....I'll try to fill them in and tap them first.
Thx
1974 Z1 900 project
  • baldy110
  • baldy110's Avatar
24 May 2015 15:27
#673531
Insert a threaded bolt from the backside then weld the bolt head to the frame. Get some aluminum round stock drill and tap a hole in the aluminum the same pitch as the threaded bolt, screw the peg onto the bolt.
[IMG
[IMG
[IMG
[IMG
  • spdygon
24 May 2015 15:39
#673534
But yours are now fixed...correct?
I'll be keeping it original .
Thx
1974 Z1 900 project
  • SWest
  • SWest's Avatar
  • 10 22 2014
24 May 2015 17:49
#673555
Mine fold back on a angle so they won't break.
  • floivanus
24 May 2015 18:41
#673572
What about a T-nut? Insert from back edge and give her a tack?
Got enough room for a timesert? Welding and drilling would be a bitch by hand. But would be your best bet to stay original, this the Z1r?
Andrew
  • spdygon
24 May 2015 19:15
#673578
I'll check out timeserts...and no not the z1r.
It's my 76kz900...doing a semi restore on it.
1974 Z1 900 project
  • floivanus
24 May 2015 19:23
#673579
Jeeze man, your sig bikes are multiplying
Andrew
