wrong forks or wrong calipers
  • Lazyman06
  • Lazyman06's Avatar Topic Author
23 May 2015 14:59
#673347
This 79' KZ1000 MKII I bought 4 years ago did not have front calipers on them. According to the PO the front calipers were locked up so they removed them while they worked on it. Now on to my dilemma, went to put the front calipers on for the first time in 4 years and they wouldn't fit. The mounting holes for the calipers were about a 1/4 in too long on both holes and it wouldn't fit between the forks and rotor. Also noticed the front forks have a schrader valve on top and as far as I know the MKII's dont have air release valves factory. So either PO swapped forks or gave me the wrong calipers which is possible because on both b/c he had a bunch of older bikes. If someone with a MKII with stock brakes could measure the mounting holes that would be fantastic. I'll post measurements as soon as I get home.
1979 KZ1000 MK II frame
1980 KZ1000 C3 police engine
  • spdygon
  • spdygon's Avatar
Re: wrong forks or wrong calipers
23 May 2015 15:06
#673348
as far as I know all kz 900 and 1000 are the same caliper...
I have a 76 , 77 , 78 kz 1000 and all are the same....they interchange.
pics would be great of the forks.
Next bike on my list is a Mkll
1978 Kz1000 Z1R. 10K Miles1
1978 kz1000 z1r 27k miles
1976 Kz900A4 (Red)21K miles
1976 Kz900A4 ( Red)7500 miles
1974 Z1 900 project
  • SWest
  • SWest's Avatar
  • 10 22 2014
23 May 2015 16:22
#673361
Pics, need pics.
The following user(s) said Thank You: PLUMMEN
  • floivanus
  • floivanus's Avatar
23 May 2015 16:40
#673362
Mkii forks I believe are the same as the other 1000s (just with the lowers blacked), 36mm diameter and without the air valves. The 81 & up 1000s have 38mm tubes with air added to them.
Kz550 forks are 36mm with air valves. Like was said though, pic time, don't be lazy now
Past; 78 kz1000, 83 kz550
Andrew
  • BohicaBob
  • BohicaBob's Avatar
23 May 2015 17:00
#673365
Be aware, when rebuilding front brake calipers, that different piston sizes were used between the calipers for the KZ900/KZ1000s('76- '78) and the KZ1000s from '79-'80. The latter group uses larger diameter pistons than the former.
I learned this lesson AFTER ordering rebuild kits and NOT checking piston sizes on calipers purchased from salvage yards - after all, they look identical. :laugh:
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Lazyman06
Re: Re:wrong forks or wrong calipers
23 May 2015 21:04
#673415
Been stupid busy this evening. Will try to get pics tomorrow after church
  • Lazyman06
23 May 2015 21:06
#673416
I did check part numbers while I was at work. The calipers fit a shat ton of different bikes while the part number for the forks only show to fit the A3 and the A3A
The following user(s) said Thank You: Randombeat
  • SWest
  • SWest's Avatar
  • 10 22 2014
23 May 2015 21:14
#673422
I'll check in with you tomorrow.
  • Lazyman06
24 May 2015 14:58
#673527
Air bleeders
  • Lazyman06
24 May 2015 14:59
#673528
Fork and calipers
  • spdygon
  • spdygon's Avatar
24 May 2015 15:57
#673535
Forks look correct but the caliper brackets don't .
Just measure my which are 36mm forks and the spacing for the caliper bracket holes are 72mm center.
1974 Z1 900 project
