Swapping MKII discs with Z1R. Will it work?
- 300kph
19 May 2015 14:39
Restoring my MKII and my rear rotor is really rusted from sitting.
I have a set of 3 drilled original discs from a 1978 Z1R. Will they fit? The drill pattern is much nicer. With the few custom touches I have planned for the MKII this is something i would do if doable!
w
w
1978 KZ1000 D1 (Z1R)
1979 KZ1000 A3 (MKII)
1979 Honda CBX (Candy Glory Red)
1980 Suzuki GS1100E (Silver)
1980 Suzuki GS1100E (Red)
1978 Yamaha XS1100
1982 Suzuki GSX1100S (Katana)
1984 Kawasaki KZ1100R (Silver)
2004 Honda Rune (Bloodstone Red)
1978 Yamaha XS1100
- pete greek1
Re: Swapping MKII discs with Z1R. Will it work?
19 May 2015 15:38
You can resurface them if they are within spec. ..I put 78 Z1R rotors on my 80 LTD 1000, ...no problem with the fronts, but the rear Z1R rotor was 1/8-1/4 inch bigger in circumference, & it wouldn't work with the LTD caliper, so I bought a 78 Z1R caliper to accommodate the bigger Z1R rotor, but later realized that I had enough room to file down the LTD caliper, to make it work....125.00 down the tube
Pete
Pete
