1981 KZ550 Rear Axle Nut Torque
  • nickleo373
  • nickleo373's Avatar Topic Author
14 May 2015 15:31
#672125
Hey everyone. I'm replacing the rear drum brake shoes on my 1981 KZ550 LTD. I used to Clymer manual to take the wheel off. I'm about to put the wheel back in place and I know the Clymer torque specs are notorious for being wrong. Does anyone know Kawasaki's FSM rear axle nut torque spec? Thanks
1981 KZ550C LTD
"If you ain't first, you're last"
  • floivanus
  • floivanus's Avatar
Re: 1981 KZ550 Rear Axle Nut Torque
14 May 2015 16:14
#672134
Just tighten until tight, not cranking it on and use a good new cotter key and you'll be fine.
Whatever the clymer spec is probably will be fine the castle nut cotter key combo will keep it together
Past; 78 kz1000, 83 kz550
Andrew
  • bountyhunter
  • bountyhunter's Avatar
14 May 2015 17:48
#672144
My 750 is about 100 foot-pounds, but I did as stated above for many decades..... just cranked as hard as I could turn it.
  • martin_csr
  • martin_csr's Avatar
14 May 2015 18:07
#672149
To install the hitch pin clip, I have to crank the nut pretty tight to line up the holes.
  • RonKZ650
  • RonKZ650's Avatar
14 May 2015 19:42
#672164
Yea, just tighten til tight and find the next slot and tighten more to line it up. Regardless of urban myth ect, over tightening the nut will not cause the bearings to fail, and likewise slightly under tightened won't hurt either as you have the castle nut and cotter pin.
