Front wheel out of alignment with handlebars
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Front wheel out of alignment with handlebars
11 May 2015 17:21
#671625
Go to Z1 Enterprizes one of our vendors here. look up your bike and if they have them, getum.
  • Hamaya
  • Hamaya's Avatar Topic Author
11 May 2015 17:22
#671627
swest wrote: Go to Z1 Enterprizes one of our vendors here. look up your bike and if they have them, getum.
Aah, that was the price of new stanchions? Nice!
I went to their website and it doesn't look like they carry any for the 550 :( I'll give them a call tomorrow and see what they have to say!
1983 KZ550-M1 LTD Shaft
  • Hamaya
11 May 2015 22:40 - 11 May 2015 22:53
#671703
Final update for awhile:
After disassembling the forks and doing the roll test, I found that both stanchions are slightly bent, one moreso than the other. No kinks, so I will contact a local shop for a quote on fork straightening. I'm not convinced the triple clamps are tweaked, so I will see where new forks get me.
Last edit: 11 May 2015 22:53 by Hamaya. Reason: grammar
12 May 2015 03:46
#671713
Hamaya wrote: Final update for awhile:
... I'm not convinced the triple clamps are tweaked.....
? Sorry, but they are. The fact that you can rock them on a flat surface, and that picture you posted next to a ruler convinces me you should replace them. They should be dead flat because the length of the fork tubes multiplies the problem. A tweaked triple tree is a bad thing that can get you into trouble quick. I highly recommend you replace them with pieces that you first test. Do this while you have the forks apart and you won't regret it. Ed
  • martin_csr
  • martin_csr's Avatar
12 May 2015 05:45 - 20 May 2015 05:24
#671721
.... I'm not convinced the triple clamps are tweaked...
When pressing down on a corner, does it move much? Mine rocked quite a bit ---- the replacement triple only a tad. And yesterday I checked a spare nos upper triple --- it also moves just a tad. I did not put a straight edge on it.
Fork tubes. Instead of trying to find the tubes, it might be simpler & cheaper to get used forks on eebbaayy. Ask a question or two before purchasing to go on record that you're looking for straight stuff --- for refund or return purposes.
Last edit: 20 May 2015 05:24 by martin_csr.
  • Hamaya
19 May 2015 12:41
#672749
I figured it was time I updated you all on my bike! I bought a used set of front forks and triple clamps off Ebay. After swapping in these parts, everything is now straight! Later this week I plan to modify a socket for the steering stem locknuts, so I can get them torqued correctly.
Thanks everyone for the help.
