82 KZ440 dual front brakes
  • Jbosh
  • Jbosh's Avatar Topic Author
  • 1982 Kz440 ltd D4
10 May 2015 08:13
#671362
Alright,
I've been chewing on this idea for a little bit. My Cafe/brat project has taken inspiration from a few guys who have put modernized front fork and brake setups on an old bike chassis. My thought is to save a few bucks and just put an extra rotor and caliber on the right side of my front forks? It's braking isn't over the moon at this point anyway. My kz has this setup already on the left. What are your honest thoughts?
- will this require a new master cylinder due to increased load?
- when you do front end brake work, should you always replace both simultaneously for the sake of equal wear and balance? Would it be smart to redo all the pads and shoes at the same time?
- has anyone done this and had issues with the fitting?
When I look at the forks, there are mounting holes already present but not in use.
Thanks a ton!
As long as I get to learn something, I'm happy!
  • Nebr_Rex
  • Nebr_Rex's Avatar
Re: 82 KZ440 dual front brakes
10 May 2015 13:58
#671407
Do a search.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
  • Jbosh
  • 1982 Kz440 ltd D4
10 May 2015 22:58
#671473
Hi Rex, I just did a search again as you suggested to no joy. Do you know of a conversation that's already ongoing that you could share a link for? It may just be that I'm not using the right terminology. Thanks for your reply!
  • Nebr_Rex
  • Nebr_Rex's Avatar
11 May 2015 04:14
#671484
Does the other fork have the bosses to bolt on another caliper?
The wheel will need some machine work or swapped for a dual disc unit.
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
  • TexasKZ
  • TexasKZ's Avatar
11 May 2015 05:22
#671487
Here is a little info to get started with. I bet loudvx has more info on his website.
www.kzrider.com/forum/5-chassis/597659-1...a-1981-kz550a#667654
  • TexasKZ
  • TexasKZ's Avatar
11 May 2015 05:26
#671488
Yes to your other questions.
The following user(s) said Thank You: Jbosh
  • Nebr_Rex
  • Nebr_Rex's Avatar
11 May 2015 05:29
#671489
TexasKZ wrote: Here is a little info to get started with. I bet loudvx has more info on his website.
440s = 33mm forks
550s = 36mm forks
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
  • TexasKZ
  • TexasKZ's Avatar
11 May 2015 05:48
#671491
440s = 33mm forks
550s = 36mm forks
Probably, but Lou said that the German market 440 came with dual discs, so the conversion may be very simple.
11 May 2015 06:10
#671497
You should use a 5/8" master cylinder for dual disks. Ed
  • martin_csr
  • martin_csr's Avatar
11 May 2015 08:40 - 11 May 2015 08:42
#671525
I wouldn't worry about the Fr Br mc just yet --- that's the easy part w many choices.
The other stuff is probably going to be a pain if no one else w a 440 can provide any specifics.
The diameter of your disk is going to determine which disks to get & possibly the wheel choices.
I'll guess getting a 750-4 front wheel & 550 disks. ??? just a guess.
Brake caliper. From the diagrams at Partzilla the left side caliper is the same as the 650C, so the 650C right side might be a direct fit.
Last edit: 11 May 2015 08:42 by martin_csr.
