Zephyr 1100 shocks on a KZ750-L3?
- TheForumTroll
27 Apr 2015 08:27 - 27 Apr 2015 09:56
Anyone know if Zephyr 1100 shocks with 345 mm between holes would fit on a KZ750L3? I can't remember the 750's shock length.
EDIT: L3, not L4 :silly:
-[ KZ700-A1 '84 ]-
Last edit: 27 Apr 2015 09:56 by TheForumTroll. Reason: Changed it to correct model (L3)
- TheForumTroll
Re: Zephyr 1100 shocks on a KZ750-L3?
27 Apr 2015 10:31
Well a bit of google search and some looking at different shock manufacturer websites gave me the following numbers which I think is correct:
KAWASAKI >Z 750 / E/L >Year 80-87: 340 - 14X20 - 14X20 (length - top - bottom)
KAWASAKI >ZEPHYR 750 >Year 91-99: 350 - 14X20 - 10X20
That would be a fit right? The 4mm smaller depth shouldn't be a problem me thinks.
-[ KZ700-A1 '84 ]-
- Mcdroid
- Gone Kwackers
27 Apr 2015 11:06
If no one answers today, let me look at my GPz750 shocks (very similar to the L3 shocks) and the set of 1100 Zephyr shocks I have. I think another issue might be the 'width' of the shocks rather than the distance between mounting holes.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- TheForumTroll
27 Apr 2015 11:33
The width of the spring or the mounting parts? Hmm, didn't think about the spring etc. :huh:
-[ KZ700-A1 '84 ]-
- TheForumTroll
28 Apr 2015 12:05
I just measured my KZ700-A1 springs (Kawasaki's diagram says they are the same). There should be ample room for bigger springs.
-[ KZ700-A1 '84 ]-
- Mcdroid
- Gone Kwackers
28 Apr 2015 17:26
The major difference is the length of the spring. On the ZR1100 shock, the spring extends to the bottom of the lower mount...or almost the length of the lower shock shaft, This lower section is then wider than the GPz750 shock, which has a bare lower shaft to the lower mount. This wider area will interfere with the chain guard and possibly rub against the bolts holding the rear sprocket. You can trim the chain guard but the sprocket bolts (if they rub) will be difficult to get around.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- TheForumTroll
29 Apr 2015 03:40 - 29 Apr 2015 03:48
I don't know how it looks on the GPZ but look at this:
If I understand correctly it shouldn't be a problem, right?
-[ KZ700-A1 '84 ]-
Last edit: 29 Apr 2015 03:48 by TheForumTroll.
- TheForumTroll
29 Apr 2015 03:45 - 29 Apr 2015 03:47
-[ KZ700-A1 '84 ]-
Last edit: 29 Apr 2015 03:47 by TheForumTroll. Reason: Uploaded to imgur instead
