Identify this 16"drum Brake cast wheel
- kzz1king
26 Apr 2015 15:37
I need a brake arm for a 16'" cast wheel I put on my Z1. The brake rod arm on the Z is shot and I am not sure if the splines are the same. I don't know what model this wheel came from. Any help will be much appreciated. It is getting nice out!
It has J16kmt 3.00 DOT stamed in one spot, R-1038 in another and Kawaski in another.
Attachment DSCN3879.jpg not found
Attachment DSCN3876.jpg not found
Attachment DSCN3882.jpg not found
Home built KZ1000 turbo setup
- missionkz
Re: Identify this 16"drum Brake cast wheel
26 Apr 2015 15:44
Is that a rear wheel from a small KZ400-440 LTD of some kind?
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
1977 KZ1000A1
26 Apr 2015 17:37
That's what I was thinking.
- Nebr_Rex
26 Apr 2015 18:10missionkz wrote: Is that a rear wheel from a small KZ400-440 LTD of some kind?
Those are 2.15 * 16.
3 * 16 are 550 and larger.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- z1kzonly
26 Apr 2015 18:23
A KZ 650
- kzz1king
26 Apr 2015 18:28
I think a 650 also. It is a 6 bolt sprocket, same spacing as the 1000's. I guess what is of most importance to me is do they all have the same spline/shaft diameter for the brake arm? I am thinking so from looking at all the drum hubs for both cast and spoked wheels.
Attachment DSCN3883.jpg not found
27 Apr 2015 05:15 - 27 Apr 2015 05:34
From the cross-reference at Partzilla a bunch of models use the same Rr Br cam shaft but not all of them. (41050-017). The cam lever seems to vary more, depending upon the model.
Last edit: 27 Apr 2015 05:34 by martin_csr.
- kzz1king
27 Apr 2015 08:35
Thanks. I tried doing some looking on ron ayers but they no longer go back that far. I will have to check out partszilla.
martin_csr wrote: From the cross-reference at Partzilla a bunch of models use the same Rr Br cam shaft but not all of them. (41050-017). The cam lever seems to vary more, depending upon the model.
- DoctoRot
27 Apr 2015 13:17 - 27 Apr 2015 13:33
If the axle is 20mm then i think it is the rear wheel off a '80, '82, or '83 KZ750 twin, the 650 and 550 had 17mm rear axles. It uses the same cam arm as a ton of other models some as recent as 2002. I have a rusty one you can have for shipping if you like. the teeth are in good condition.
www.partzilla.com/parts/detail/kawasaki/KP-42029-039.html
Last edit: 27 Apr 2015 13:33 by DoctoRot.
- kzz1king
27 Apr 2015 17:52DoctoRot wrote: If the axle is 20mm then i think it is the rear wheel off a '80, '82, or '83 KZ750 twin, the 650 and 550 had 17mm rear axles. It uses the same cam arm as a ton of other models some as recent as 2002. I have a rusty one you can have for shipping if you like. the teeth are in good condition.
Thanks, I just bought a 650 one off of ebay. Will see how that works out. Thanks
Wayne
- I_Tig_in_piece
28 Apr 2015 03:33
That wheel looks exactly like mine from an 81 KZ440.
Apparently I haven't really taken much right side pictures? Gonna have to fix that. If you need any kind of measurements or spline count, lemme know.
ed
ed
Cheap labor isn't skilled, skilled labor isn't cheap.
1980 KZ440a. I went green.
If you yourself are building an older bike and can see it through till you're riding it, that's proof you have patience.
