Q: stem bearings swap
- yeekim
16 Apr 2015 04:35
HI!
A quick question:
Can I use the all ball bearing kit like this:
www.motosport.com/all-balls-steering-bearing-kit
instead of original loose ball system
www.partzilla.com/parts/search/Kawasaki/...elt/FRAME/parts.html
It's '82 750TWIN belt
wbr
A quick question:
wbr
Ex nihilo nihil fit!
Re: Q: stem bearings swap
16 Apr 2015 05:01 - 16 Apr 2015 05:03
Yes. It is a very common upgrade. You can also buy them directly from All Balls.
www.allballsracing.com/
Last edit: 16 Apr 2015 05:03 by TexasKZ.
The following user(s) said Thank You: yeekim
- yeekim
16 Apr 2015 08:14
TNX!
So, there is no other issue than old out and new in :whistle:
- JimB
16 Apr 2015 09:11
Yes,...they work fine. Make sure you do not distort them when getting the new ones in
A brass hammer, wood block to push them in or long threaded bolt with washer/ nut set up to pull them in will work
1978 KZ1000A2, 1980 KZ1000E, 1980 KZ1000B4 LTD
