KZ400 Fuel Tank Compatibly
  • bmatyeah
  • bmatyeah's Avatar Topic Author
15 Apr 2015 18:24
#668122
Can someone point me to or have a resource on fuel tank compatibly. I just purchased a 78 Kz400 and It needs a new gas tank. I don't see any for sale here recently, and ebay ones are really rusty or quite expensive. I think I need to expand my search to see what other years will fit. If anyone has any insight please help!
78 KZ400B1
  • ThatGPzGuy
  • ThatGPzGuy's Avatar
Re: KZ400 Fuel Tank Compatibly
16 Apr 2015 04:14
#668163
I had to purchase a tank for my KZ400 and was able to find a clean one in the right color on ebay for $50 or so. Don't be too worried about the rust issue, If it is solid and it is just the inside of the tank that is rusty you can achieve amazing results with a battery charger and some rust remover. I took an old XS650 tank that was very rusty inside but fine otherwise and made it look like new.
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
  • martin_csr
  • martin_csr's Avatar
16 Apr 2015 07:54 - 16 Apr 2015 08:30
#668190
Try comparing tanks at Partzilla or Kawasaki.com. At least some rust is to be expected.
A 70s KZ400 with the same method of attachment would be the best fit.
The 78 B1 has a tab & damper, so I would get the same type. KZ400 B1, C1, B2. Others?
The 80 KZ440-B tank appears to be very similar, so maybe??? Red dented
You could check the later 440 models to see if there are any others, but I think they are different.
With a non-stock tank the front mounts may not line up right or the tank might not clear the frame or the length could be off or have a different rear mount or something.
Some models attach at the rear with a bolt or a band/strap, so adapting one of those would take some work. I have no idea how hard it would be, but it might be doable, assuming that one of those fits the frame otherwise.
Last edit: 16 Apr 2015 08:30 by martin_csr.
  • bmatyeah
16 Apr 2015 17:39
#668270
Thank you for the help!
78 KZ400B1
