rear tire size.
- oldsguy
rear tire size.
12 Apr 2015 05:26
Thanks for having me. Im a new KZ owner..recently aquired a 76 KZ900, and im looking for 2 things..1) what is the Best/easiest upgrade for ignition from points to electronic? 2) What is the widest tire size I can put on rear stock wheel? Thanks for any advice..randy
Re: rear tire size.
12 Apr 2015 05:36
You can fit a 130/90-18 tire on the stock wheel BUT it isn't a great idea to do so. I ran 130 tires on the rear of my bike for many years. Eventually I discovered that because the rim pinches in that wide tire it deforms the cross section of the tread. As a result, the 130 tire doesn't work any better than the 120/90-18 tire; in fact, maybe not as well as the 120, plus it's a pain in the butt to mount. Also, on my bike the 130 rubbed on the stock chain guard so I had to buy an aftermarket guard. The 130 does look good on there though. :laugh: Ed
The following user(s) said Thank You: missionkz
- Gman
Re: rear tire size.
12 Apr 2015 08:19
For ignition upgrade, it is hard to beat the Dyna S. It will work fine with stock coils.
1978 KZ1000
1965 Harly Electra Glide
2002 Gold Wing
1974 Z1 900 project
2002 Gold Wing
1974 Z1 900 project
- 78z1Joe
- My man cave is my garage....
Re: rear tire size.
12 Apr 2015 08:39
Hi yes both 650Ed and Gman are correct. 120/90 is the best fit, ride combination, no need to go larger and shouldn't go smaller. I've run Dyna S electronic ignition and Accel yellow coils for almost 30 years, no problems. I'm sure if you went with Dyna 3 ohm coils, they would be excellent as well. Welcome and good luck.
Joe
Joe
1978 KZ 1000
1982 GS 300 training bike
Previous Rides...
75 RD 350
72 CB 500 Four
72 SL 125
71 CT 70
69 3 1/2 HP mini bike
Previous Rides...
75 RD 350
72 CB 500 Four
72 SL 125
71 CT 70
- DoctoRot
Re: rear tire size.
16 Apr 2015 18:07
I recently found out that the Avon am26 and the bridgestone bt45 both still come in standard sizes. You can get a 3.25x19 and a 4.00x18 which are the prescribed sizes from the factory. Im gonna try them out next time i need tires.
Re: rear tire size.
16 Apr 2015 19:31
I went with the 410 front and 510 rear 35 years ago. That's wen I ran the K81 and IRC rear. Later I went with the K181 and Chin Shin rear. When I put my bike back on the road two years ago, I had to go with different brands, one to save money, two because Chin Shin no longer males road tires for bikes, at least that's what I was told. They got sew'd and lost. I bought a 100/90-19 for the front and a Nang Kang for the back. It handled like SHT on my dirt road and was squirrely in the turns. I wore out that POS and went with the Tour Master 110/90 front and 130/90-18 in back. It holds the road, I'm confident in the turns but still I go though a rear tire in four months. The bike is my daily driver. I have a truck but the bike wins.
