gear ratio
- jlat
gear ratio
31 Mar 2015 14:59 - 31 Mar 2015 15:01
hello people: I'm new. I know there's a way to do it and I'm far away to worry about it. But to anyone with a 1000 and running a 630 chain 15 tooth engine and 39 wheel. What RPM are you seeing at 70 MPH?
thanks
IBBY
thanks
IBBY
Last edit: 31 Mar 2015 15:01 by jlat.
- pete greek1
Re: gear ratio
31 Mar 2015 15:26
I'm running a 15/32, & i''m at around 4ooo RPM sock is 15/33, I went to a 32 to lower my RPMs on the Highway
Your motor must be Screaming at over 6000 RPM, with the 39
Pete
Pete
- jlat
Re: gear ratio
31 Mar 2015 16:16
hello; What's the redline on a 1000? How about the power band? Is the power nice all thru the RPM? I've ridden a few 1000's and I remeber the power was nice from low to high RPM's
Go Bruins!!!!!
IBBY
Go Bruins!!!!!
IBBY
Re: gear ratio
01 Apr 2015 05:59
What particular model is it?
81 1000 Ltd : 630 stock chain & sprockets = 15T Fr & 39T Rr.
The speedo indicates that redline is 8500 rpms.
The bike is loaded into the database at GearingCommander --- approx. 4400 rpms @ 70mph.
- MFolks
Re: gear ratio
01 Apr 2015 08:30
Use
www.gearingcommander.com
when figuring ratios.
- jlat
Re: gear ratio
01 Apr 2015 16:14
hello people; My KZ 1000 is a 77A engine in a Santee frame. I've had this project for years. Engine has never been run since I've had it and the frame never painted. I don't remember anything about the engine but it looks cleaned up as with my timing f*** up the head is off and there's no carbon in it at all.
I do have a new 39 rear sprocket and was wondering if any 1000 owners run it.
I tried that ratio site but my puter seems to get stuck there when I do.
IBBY
IBBY
Re: gear ratio
01 Apr 2015 17:38
I have a 16 tooth and 33 rear. Stock is 15/33 on the Z1. I'm at 4000 at 70 MPH.
