chrome controls for kz550
- fastdave
22 Mar 2015 11:10
Does anybody know of a set of chrome handlebar controls that will work on a 1983 kz550 ltd? I was hoping for something that will swap right over. Thanks if you do.
Faster is more fun
- Tyrell Corp
Re: chrome controls for kz550
22 Mar 2015 11:48
I stripped the paint off and mirror polished the switch halves. Chrome plate on aluminium doesn't last like plating steel.
Alternatively, find some switchgear - anything for 7/8 bars and change the block connector. My z1000 is wearing modern triumph switchgear. The only other thing is if taken from a modern bike you may need to use a relay for the lights; the thin wires and switch contacts won't reliably handle the current of a headlight circuit.
- fastdave
22 Mar 2015 12:31
Thats cool. But whatabout the levers and clamp parts of the lever. I think my kz has plastic switch housing,
Faster is more fun
- Tyrell Corp
22 Mar 2015 15:04 - 22 Mar 2015 15:11
Same with the levers and clamp, they are aluminium...what I said in the other thread about once you start detailing you can't stop. Some levers are anodised black but you can buy cheap pattern levers in unfinished aluminium.
I don't have a close up of the handlebar controls but all the aluminium was stripped an polished. Grips and pegs are chrome sundance custom. This one I did about 20years ago, not the way I'd do it now but that was what was in my mind's eye then.
Attachment 142706153666368.jpg not found
Last edit: 22 Mar 2015 15:11 by Tyrell Corp.
- fastdave
22 Mar 2015 18:26
Hey that looks good. I guess Im going to continue polishing like I have been. It just takes soooo long. View my build in the projects forum under 1983 kz550 ltd. I think ill be done by next spring .lol
It is nice to be able to polish what you have. it looks like you did a nice job on your project too.
Faster is more fun
- fastdave
31 Mar 2015 16:29
Nope I was wrong the control housings are aluminum. I guess its more polishing for me.
Faster is more fun
- DoctoRot
This bike is badass! do you have anymore pics?
