Leaking fron fork
  • ewolpert
  • ewolpert's Avatar Topic Author
Leaking fron fork
09 Mar 2015 12:03
#663871
So now that my bike is working, I have been riding all over the place. This is fun, but one of the front forks is leaking oil and I need to fix that issue. What do I need to get in order to rebuild the forks? I cannot seem to find a good guide online. Thanks.
Eddie
78 KZ650 b2a
Re: Leaking fron fork
09 Mar 2015 12:59
#663875
Leaking from the fork seals? The forks don't need to be "rebuilt" as there really aren't any internal parts that get replaced. If the fork seals are leaking you just replace the seals, and should probably replace the dust shields while you're at it. However, the fork oil should be flushed out and the internals should be clean. Fork oil should be changed at least every 2 years. Be sure to use the instructions in the Kawasaki Service Manual so you fill the forks to the correct level. Ed
  • davido
  • davido's Avatar
09 Mar 2015 13:40
#663876
As above. Seals,dust covers and oil.
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
  • SWest
  • SWest's Avatar
  • 10 22 2014
09 Mar 2015 13:40
#663877
Are your forks tweaked? That could cause one to leak.
  • ewolpert
09 Mar 2015 17:22
#663905
swest, I do not believe they are tweaked. They don't look like it. The one that is leaking was barely seeping before, now it is full on leaking and I may have done something to the seal.
I will get new shields and seals, thanks guys.
Eddie
78 KZ650 b2a
  • ewolpert
09 Mar 2015 17:40
#663907
Also, what kind of oil goes in there?
Eddie
78 KZ650 b2a
09 Mar 2015 18:27
#663911
Fork oil. I have always used 15w Bel Ray fork oil and it works great in my KZ650. Use the Kawasaki Service Manual to learn how to fill to the proper level.
  • ewolpert
09 Mar 2015 19:52
#663921
Thanks Ed, will do.
Eddie
78 KZ650 b2a
  • SWest
  • SWest's Avatar
  • 10 22 2014
09 Mar 2015 20:22
#663925
You don't have a front fender. The forks might be out of alignment. Even with a fender, I can tweak them by nudging something. It doesn't take much.
  • LuckyLucOnBass
  • LuckyLucOnBass's Avatar
09 Mar 2015 20:31
#663929
ewolpert wrote: So now that my bike is working, I have been riding all over the place. This is fun, but one of the front forks is leaking oil and I need to fix that issue. What do I need to get in order to rebuild the forks? I cannot seem to find a good guide online. Thanks.
This video + the service manual will = a good job.
bass player, bike rider, hockey fan.
1983 KZ550 M1
