Lock Washers ??
  • kzdcw
  • kzdcw's Avatar Topic Author
  • 77' KZ1000A
Lock Washers ??
05 Mar 2015 19:27
#663602
Kawasaki uses Lock Washers #92088023 on the Disc Brake Rotors and Lock Washers # 92088007 on the Sprocket Bolts.
Can you use "Regular" Lock Washers sized for the bolts used and Blue-Locktight ?
Would that be ample for the job ?
77' KZ1000A
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Lock Washers ??
05 Mar 2015 20:19
#663612
You can use metric lock washers. I wouldn't use Lock Tight.
  • !Seymore
  • !Seymore's Avatar
  • Ride on...
Re: Lock Washers ??
05 Mar 2015 23:48
#663619
kzdcw wrote: ...and Blue-Locktight ?
No locktite. Just torque to spec...
C.
79' KZ650-D2 [fsm] (Max)
83' KZ750-F1 LTD [clymers] (Kay)
82' KZ1100-D1 Specter (another project)
78' KZ650-B2a (J&H, A Project)
91' KZ1000-P (P = parts)
  • HBKwaka
  • HBKwaka's Avatar
Re: Lock Washers ??
06 Mar 2015 14:26
#663645
Any grade 6 or AN/MS/NAS level lock washer would work. If it works on a plane or rocket it would be over kill for a Zed
