Which rims do i have on?
  • TheDane
  • TheDane's Avatar Topic Author
23 Feb 2015 14:29
#662513
Hi
My KZ550 is a mix of different KZ's
The frame is a KZ400J '81 and engine is a KZ550A1
But I'm not sure which model the wheels are from.
The front rim says
f-1044
tubeless
J 19XMT1.85 DOT
ENKEI-5
Double disc breaks
The rear rim says
r-1043
tubeless
J 18XMT2.15 DOT
ENKEI-4
It is with break disc
Attachment 2014-05-0416.52.31_2015-02-23.jpg not found
Do anyone know what model it could be from?
Kawasaki
EngineKZ550A 1980
Frame KZ400J 1981
  • Nessism
  • Nessism's Avatar
  • Away
  • Tyrell Corp
  • Tyrell Corp's Avatar
Re: Which rims do i have on?
23 Feb 2015 16:05
#662519
7 spoke cast mag wheel standard issue for all the 400/500/550 and numerous others of that era.
The US model kz550 had a drum rear, the euro model a disc IIRC.
Looking at the distinctive footpeg triangles and the frame mounted rear master cylinder tabs I'd guess your rims are standard equipment to that bike.
I do rather like the 550's, had about 10 over the years since a teenager.
The following user(s) said Thank You: TheDane
  • TheDane
23 Feb 2015 16:19
#662521
Thank you. That answers all my questions about that :)
Kawasaki
EngineKZ550A 1980
Frame KZ400J 1981
