KZ550 LTD Rear Brake Cam/Lever and Rod Position
  • The_Proletariat
  • The_Proletariat's Avatar Topic Author
  • "Cocaine is a hell of a drug"
23 Feb 2015 11:57
#662493
Hello,
1982 KZ550 LTD
I am about to get around to installing some discontinued parts I located last year. I have a few questions and I am still unclear after reading the FSM.
I understand the rear brake lever should be 80-90 degrees with the brake fully applied. My question is, how far should the brake rod nut be threaded on the brake rod with nearly new brake shoes?
1982 Kawasaki KZ550 LTD
  • martin_csr
  • martin_csr's Avatar
Re: KZ550 LTD Rear Brake Cam/Lever and Rod Position
23 Feb 2015 12:17
#662495
There probably isn't a spec for the nut's position.
On my 81 650-CSR the brake rod extends about 10mm beyond the nut.
