Spacer size
  • Lazyman06
  • Lazyman06's Avatar Topic Author
Spacer size
05 Feb 2015 15:34
#660716
I seem to be missing an axle spacer on the rear, but I may be able to make one. All I'm needing from you wonderful people, is the dimensions of said spacer. Don't have a picture but it's part# 42032-071 and its part index #4 on the Kawasaki micro fiche.
Or if anybody has a suggestion for a replacement that would be wonderful.
1979 KZ1000 MK II frame
1980 KZ1000 C3 police engine
  • gcphoto
  • gcphoto's Avatar
Re: Spacer size
05 Feb 2015 15:46
#660717
which bike and year? Same thing happened to me last year on my 78 kz650. I found one on ebay no problem.
'78 KZ650 SR
___________
Wear a helmet, pants are optional.
  • gcphoto
  • gcphoto's Avatar
Re: Spacer size
05 Feb 2015 15:47
#660718
No eBay APP ID and/or Cert ID defined in Kunena configurationif the bike is the one in your footer it's the 81 kz1000? would this work?
'78 KZ650 SR
___________
  • Lazyman06
Re: Re:Spacer size
05 Feb 2015 21:40
#660748
I found them on eBay but it was $50. Not sure about the one in the link. I'll have to check it out when I get to work tomorrow
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Re:Spacer size
06 Feb 2015 07:26
#660764
Just don't buy from that guy with the silver dollar in all his adds. He thinks his stuff is gold, lies and takes advantage every time he gets a chance. Hoping someone will need the part so he can GANK them.
  • Mk.2
  • Mk.2's Avatar
Re: Spacer size
06 Feb 2015 10:38 - 06 Feb 2015 10:55
#660772
Sir,
If you can provide detailed dimensions I'd be happy to machine it for you, just cover shipping and material.
went out to the shop.... that spacer is 15mm thick 40mm OD with 20mm thru for the axle. doesn't get any easier than that. Probably low carbon steel like 1018 then you can plate it if you want it to look factory or use SS then you don't have to worry about it but material is more.
Christ! I can't believe those jokers on ebay wanting $48 for a simple spacer, 15-30 minute job to make one depending on stock size.
Matt
KZ1000A1--current project
KZ1000A3A
Phoenix
Last edit: 06 Feb 2015 10:55 by Mk.2.
  • Lazyman06
Re: Re:Spacer size
06 Feb 2015 18:58
#660806
Mk.2, it should just be the stock spacer size. I'm keeping the stock wheel, swingarm, tire, all that good stuff. About how much do you think it'd be. Zip is 72401 for shipping purposes
  • Mk.2
  • Mk.2's Avatar
Re: Re:Spacer size
08 Feb 2015 07:34
#660925
I would use low carbon steel like OEM but will be much better quality than they used, this will be cheapest. I would think material cost no more than $10
Not sure but flat rate shipping should be $5.00 anywhere, you may want to confirm this, I'm in Phx 85083
If you want stainless or titanium the material cost will jump accordingly.
Matt
KZ1000A3A
Phoenix
  • Lazyman06
Re: Re:Spacer size
08 Feb 2015 07:39
#660930
Its either 5 or 7 now can't remember but that sounds great. Let me know the details and we'll get this ball,or wheel in this case, rolling
  • Mk.2
  • Mk.2's Avatar
Re: Re:Spacer size
08 Feb 2015 07:44
#660932
I'll get it made this week and get you a pic when its done
Matt
KZ1000A3A
Phoenix
The following user(s) said Thank You: Lazyman06
  • Mk.2
  • Mk.2's Avatar
Re: Re:Spacer size
13 Feb 2015 19:47
#661557
you have email
Matt
KZ1000A3A
Phoenix
