Sprockets
  • JR
  • JR's Avatar
Re: Re:Sprockets
09 Feb 2015 19:52
#661116
whirlwind598 wrote: @JR mines an 83 h4 stock should be 13:32 with 88 links on a 630.
Ok
then your rpm @ 60 mph should be less than my current 5000
Like Ed said something must be wrong
bike is under a cover in the carport. I can't even look at it until mid March when the temperature warms up and the snow melts.
Good luck
Re: Re:Sprockets
09 Feb 2015 20:25
#661123
whirlwind598 wrote: Speedo only goes to 85.
That was a federal mandated speedometer that has nothing whatsoever to do with the top speed of the bike. When running properly and with the stock sprockets the KZ750 4 cylinder bike will exceed 125 mph. Ed
  • bountyhunter
  • bountyhunter's Avatar
Re: Re:Sprockets
09 Feb 2015 21:50
#661125
I actually remember that idiocy.
People may not remember that they actually introduced legislation to force car makers to put circuitry in the cars to make the lights flash and horn blast if the speed went above about 75. That never got put into law, but what a time it was.
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Re:Sprockets
10 Feb 2015 06:09
#661141
The DOT made them change the gauges. No votes were involved. Don't think it won't happen again. "You can keep your old plan,you can keep your doctor if you want to".
  • whirlwind598
  • whirlwind598's Avatar Topic Author
Re: Re:Sprockets
15 Feb 2015 21:33
#661736
Everything I've read says the 750 I have never went over 111mph on stock parts
  • whirlwind598
Re: Re:Sprockets
15 Feb 2015 21:35
#661737
Either way some of the guys in my area said it should be fine on the engine as long as im not racing it, and it could be beneficial on the clutch
  • Xl ED
  • Xl ED's Avatar
Re: Sprockets
16 Feb 2015 05:02
#661748
Sounds like if you are drag racing this setup should be fine. If you using it as a city bike it would be ok. If you take it on the highway a lot you are wearing it out twice as fast and likely getting half the mileage.
I don't live to ride, I ride to live.
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Sprockets
16 Feb 2015 05:49
#661751
It's a trade off. Jack rabbit starts or purring along at 70. I do more HWY riding out here. Everything is at least 20 miles away. Tall gearing makes the most sense out here. B)
Re: Re:Sprockets
16 Feb 2015 07:20 - 16 Feb 2015 18:08
#661759
whirlwind598 wrote: Everything I've read says the 750 I have never went over 111mph on stock parts
:ohmy: :ohmy: :ohmy:
Something is terribly wrong; PLEASE help us understand what you are riding. What year and model motorcycle do you own? There has never been a 4 cylinder KZ750 model that would not exceed 120 mph. I know this from personal experience, but if that isn't enough here are specs on a 1980 KZ750 LTD. Notice the top speed is 125 mph (and that was the slowest KZ750-4 model). Ed
www.motorcyclespecs.co.za/model/kawasaki...aki_z750ltd%2080.htm
Last edit: 16 Feb 2015 18:08 by 650ed.
  • H1Vindicator
  • H1Vindicator's Avatar
Re: Re:Sprockets
16 Feb 2015 17:43
#661817
With the new sprockets setup, it might not even make it to 100 now, unless he wants to risk killing the engine.
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Re:Sprockets
16 Feb 2015 21:02
#661830
Lessons are sometimes hard learned.
  • whirlwind598
Re: Re:Re:Sprockets
21 Feb 2015 09:58
#662239
I've said plenty of times before. I even tried adding it to my signature which apparently didnt work...
1983 kz750 h4 ltd.
