Lower leg stanchions
  • HBKwaka
  • HBKwaka's Avatar Topic Author
29 Jan 2015 08:55 - 29 Jan 2015 09:17
#660033
Can anyone with a better measuring system confirm the dimensions of the lower leg stanchions on a 96 KZP. I get 56mm diameter and 220mm between.
Attachment IMG_0975.jpg not found
Attachment IMG_0976.jpg not found
Attachment IMG_0977.jpg not found
Last edit: 29 Jan 2015 09:17 by HBKwaka.
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Lower leg stanchions
29 Jan 2015 12:21
#660055
Why? BTW, there is a fork balancing unit on eBay I've had my eye on. It's for 38mm forks. Mine are 36. $12.50 plus $5.75 shipping. I thought about using thicker O rings but decided against it. 1982 1100 Specter.
The following user(s) said Thank You: HBKwaka
  • Tyrell Corp
  • Tyrell Corp's Avatar
29 Jan 2015 13:36
#660059
I'd use big verniers on that, if you can.
I had a look here but no kz1000P listed
www.fastfromthepast.com/PDF/fork_brace_dimensions.pdf
I have also heard that the spacing is wider on these P models.
  • HBKwaka
29 Jan 2015 17:48
#660084
Yea i called Fast, He told me as far as he knows no one makes a brace for the KZP. I wanted one when I install the new fender. Now I will modify the stock bracket to work. No worries. Mahalo again
  • HBKwaka
29 Jan 2015 17:50
#660086
Where on ebay? I am removing the front fender and it is bolted thru the top to a bracket. Worse case I will mod the fender to work. Was looking at all options.
  • Kapahulu
  • Kapahulu's Avatar
30 Jan 2015 00:51
#660105
HBKwaka wrote: Mahalo again
Where are you from HBKwacka?
2strokeworld.com
  • HBKwaka
30 Jan 2015 07:29
#660119
Kali but spent lots in Hawai'i(Pearl City).
  • Tyrell Corp
31 Jan 2015 09:43
#660219
No eBay APP ID and/or Cert ID defined in Kunena configurationThe 56mm fork tops is standard for the big zeds, also some big suzukis, you could make a longer ally bridge plate .
Most 'micron' style fork braces are slotted so there is often an extra 10mm available. These guys might even make a one off bridge plate for their 56mm tops:
The original mudguard (fender) mounts have a pressed steel fork brace built in, so it acts as a brace with just a touch of flex, when replaced with a plastic mudguard a fork brace becomes a lot more important.
  • SWest
  • SWest's Avatar
  • 10 22 2014
31 Jan 2015 10:11
#660221
Very nice. How much in US dollars?
  • HBKwaka
31 Jan 2015 16:43
#660260
Been in convo with those fellas. Offered to make a custom for 25 more quid. Base price is 138. bout 245.00 US
  • DoctoRot
  • DoctoRot's Avatar
31 Jan 2015 19:27
#660268
That doesn't seem too bad for a one off part
