2003 ZX6 Rim with 07 ZX6 Hub - Does that work?
  • eofa
  • eofa's Avatar Topic Author
21 Jan 2015 16:04
#659300
Question:
Converting 84' GPZ1100 to a ZX6 rear end.
I have the 636 swingarm, 2003 ZX6 rims and a 07 ZX6 rear hub. Does the 07 hub work with the 03 rim?
I will also be doing the 530 chain/sprockets conversion too.
Let me know fellas.
-- Eric
Don't be dumb.
  • NakedFun
  • NakedFun's Avatar
Re: 2003 ZX6 Rim with 07 ZX6 Hub - Does that work?
21 Jan 2015 16:55
#659309
I am not completely sure, but yes I think it is as most of the modern wheels use a lot of the same parts, but the Kawi site will be your friend....
www.kawasaki.com
Go to the owner's section, then select parts diagrams. You can bring upyour bikes in question and identify the parts you want to know about. Then click on the question mark, and it will show you all the bikes that part is used on. The only hitch is that Kawi may have the same physical part, but paint or color may be different, thus the part number won't be the same.
Also for the sprockets, great prices, made in the US, and lots of options.
www.pbisprockets.com
You will most likely need an offset front sprocket which they carry.
Cory
2008 Kawasaki Concours 14
1999 Kawasaki ZRX1100
1976 Kawasaki KZ900
  • StreetfighterKz
  • StreetfighterKz's Avatar
Re: Re:2003 ZX6 Rim with 07 ZX6 Hub - Does that work?
21 Jan 2015 17:30
#659315
If you have the parts, can you not just try to fit them together?
Later, Doug
1978 z1000 Streetfighter
1976 z900 Stripfighter
1978 Z1R (roller)
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
