cast alloy microcracks in transmission parts
- Tyrell Corp
14 Jan 2015 00:18
No eBay APP ID and/or Cert ID defined in Kunena configurationI've noticed microcracks in both rear sprocket hub and clutch pressure plate. These can grow into bigger cracks over time. I' ve had a rear caliper break and another cracked sprocket hub over the years. It seems that metal fatigue in cast alloy parts is something to watch for.
Just noticed the clutch pressure plate on my 1100, I can't post pics here, but here is an example of what I mean:
The oil has almost worked like a crack testing dye to highlight the cracks. Whether this is crazing on the surface or the cracks go deeper I don't know. My pressure plate looks worse than this.
- zed1015
Re: cast alloy microcracks in transmission parts
14 Jan 2015 02:06 - 14 Jan 2015 04:02
Those markings on the pressure plate are surface casting flash and not cracks.
It is common, and of all the pressure plates I have skimmed and modified over the years for drag racing lock - ups etc they have never extended below the surface.
Last edit: 14 Jan 2015 04:02 by zed1015.
The following user(s) said Thank You: PLUMMEN, 531blackbanshee, Tyrell Corp
- Tyrell Corp
14 Jan 2015 10:27
Thanks, I'll try and get a pic, I can see the casting flash too but it also looks to me like surface cracking.
If it was crazed all over maybe, but the cracks seem to be growing from the strengthening ribs.
I had a really nasty crack on the rear hub sprocket carrier on my 1000R, about 2 inches long. I could probably have put a feeler guage in it. I scrapped the part but maybe should have kept it for my 'black museum' of wrecked parts. Also not the sort of thing that gets noticed until a sprocket or bearing change.
Hopefully the rear caliper and hub was a freak event, and I'm wrong on this pressure plate. The other issue would be even if the component IS weakened, if it was made with a 200 or 300 percent safety margin then probably nothing to worry about.
I guess if you are drag racing these and skimming them then any design weakness in this pressure plate casting would be apparent by now.
