Gas Cap Rubber Gasket ???
  • kzdcw
  • kzdcw's Avatar Topic Author
  • 77' KZ1000A
09 Jan 2015 04:06
#658139
Noticed my Stock Gas Cap rubber gasket on my 77' KZ1000A is cracked around the whole outer circumference. Like to replace it.
I see 2 different part #'s listed for it from different Venders?
51059-008 or 1109-1051
Will either one above fit my Gas Cap? Can't tell from the pictures?
77' KZ1000A
  • RonKZ650
  • RonKZ650's Avatar
Re: Gas Cap Rubber Gasket ???
09 Jan 2015 05:16
#658140
51059-008 is the Kawasaki part number, the other number is not a Kawasaki number. The gasket is no longer available unless you find one sitting on the shelf.
  • SWest
  • SWest's Avatar
  • 10 22 2014
09 Jan 2015 05:24
#658141
What about z1enterprizes or z1partsinc?
09 Jan 2015 05:27 - 09 Jan 2015 05:29
#658142
No eBay APP ID and/or Cert ID defined in Kunena configurationHere's a replacement. Ed
Last edit: 09 Jan 2015 05:29 by 650ed.
  • SWest
  • SWest's Avatar
  • 10 22 2014
09 Jan 2015 05:48 - 09 Jan 2015 05:52
#658145
Beware buying NOS rubber parts. I bought my fork dust boots from Z1 and they started cracking 6 months later.
Attachment Dustboots003.jpg not found
I sent a e-mail about it but got no response.
Buy new.
Last edit: 09 Jan 2015 05:52 by SWest.
  • SWest
  • SWest's Avatar
  • 10 22 2014
09 Jan 2015 05:50
#658146
Attachment Dustboots005.jpg not found
09 Jan 2015 07:54
#658167
Z1E indicates "temporarily out of stock."
www.z1enterprises.com/ItemDetails.aspx?i...78%29&item=51059-008
Good Fortune! :)
  • kzdcw
  • 77' KZ1000A
09 Jan 2015 23:00
#658232
Actually Part # 11009-1051 is a Kawasaki Part #. Shows it fits 81' and up. Has anyone used this Gasket for earlier KZ's?
77' KZ1000A
10 Jan 2015 08:10
#658262
Rendering Error in layout Message/Item: Kunena\Forum\Libraries\BBCode\KunenaBBCodeLibrary::renderEbayLayout(): Argument #1 ($ItemID) must be of type int, string given, called in /home/kzride5/public_html/libraries/kunena/src/BBCode/KunenaBBCode.php on line 319. Please enable debug mode for more information.
10 Jan 2015 08:30
#658268
kzdcw wrote: Actually Part # 11009-1051 is a Kawasaki Part #. Shows it fits 81' and up. Has anyone used this Gasket for earlier KZ's?
I have no personal experience with that, but I noticed that the '81 and up gas cap is totally different than the 1977, so that may be why it requires a different gasket. I recommend you get a gasket that has the part number listed in the parts diagram for your model bike. Ed
  • RonKZ650
  • RonKZ650's Avatar
10 Jan 2015 08:30
#658269
Sorry about my mistake on the part numbers. The 51059 number is still the one you want, the 1109 number was used starting with the 79 KZ1000 that used an entirely different cap. I doubt they could interchange.
