1985 GPZ 550 rear disk, speedo and grips
  • Mark Ohio 1976
  • Mark  Ohio 1976's Avatar Topic Author
29 Dec 2014 14:07
#657329
Hello,
I got the engine/trans fixed on my bike. Fixed the bent shifter fork, made a new exhaust baffle and jetted my carb.
After a test ride I noticed a couple things. First the speedometer does not work. I checked the cable and it seems ok.
Second item is the rear disk. The pads are gone and the rivets have worn the rotor. Can the rotor be turned? What is the economical way to repair?
The foam grips are toast. What grips do you recommend?
Thanks!!
Re: 1985 GPZ 550 rear disk, speedo and grips
29 Dec 2014 14:25
#657331
These folks resurface motorcycle disks properly. Ed
www.truedisk.net/
  • Mark Ohio 1976
Re: Re:1985 GPZ 550 rear disk, speedo and grips
29 Dec 2014 16:02
#657337
Thanks Ed, I will give that a try
  • Grumpy Ole Artist
  • Grumpy Ole Artist's Avatar
  • Eschew Obfuscation!
06 Jan 2015 08:07
#657895
These Oury grips (in Black ) are what I use...Love em! www.riderapparelhub.com/ORIGINALATV_BLUE...std_Flange?src=BingS
1978 KZ650 B2
Former rides...1976 CB360T, 1985 Shadow 700, 1985 GPZ750Turbo
