transmission swap
  • Josh1100
  • Josh1100's Avatar Topic Author
transmission swap
03 Dec 2014 20:10
#655290
I have a 82' kz1100
is it possible to swap a chain drive transmission, and swing arm? maybe off a gpz1100?
  • floivanus
  • floivanus's Avatar
Re: transmission swap
03 Dec 2014 22:20 - 03 Dec 2014 22:20
#655295
Yep, swap the transmission output shaft, shift drum, shifter and trans door; then mod a swingarm to fit, find a clutch cover, and maybe a clutch pushrod. Any 81-2002 kz1000 chain drive parts should work
Past; 78 kz1000, 83 kz550
Andrew
Last edit: 03 Dec 2014 22:20 by floivanus.
The following user(s) said Thank You: Josh1100
