Z1R Bars on a 72 Z1
  • Yorkie
  • Yorkie's Avatar Topic Author
Z1R Bars on a 72 Z1
24 Nov 2014 17:13
#654547
I own a '72 Z1 and I am not a fan of the stock bars so I was thinking of fitting some Z1R bars I have lying around. If I fit these bars will I be forced to change out the cable and brake hose or will the stock US parts work with the Z1R bars? I also have some superbike bars and was wondering the same thing about those.
Thanks
'72 Z1
  • kaw-a-holic
  • kaw-a-holic's Avatar
Re: Re:Z1R Bars on a 72 Z1
24 Nov 2014 17:24
#654550
Unless it's a Harley they all have 7/8" inch bars. The only challenge might be the locator hole for the hand controls and the oval hole in the center of the bars for the wiring.
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
  • GregZ
  • GregZ's Avatar
Re: Z1R Bars on a 72 Z1
24 Nov 2014 17:28 - 24 Nov 2014 17:33
#654553
The stock cables are a little long as is the brake hose. The brake hose can be re routed behind the headlight and looks ok out of sight. Throttle & clutch cables stick out little to far. Your best is to go ahead and order shorter cables. Z1 enterprise has what you need.
I'd be more then happy to buy them Z1R bars from you
gregz
Last edit: 24 Nov 2014 17:33 by GregZ.
  • GregZ
  • GregZ's Avatar
24 Nov 2014 17:31 - 24 Nov 2014 17:34
#654554
Read the description and dig around to find short clutch cable or call Rob at Z1 he will fix you up.
www.z1enterprises.com/ItemDetails.aspx?i...f1000&item=MP03-0001
Last edit: 24 Nov 2014 17:34 by GregZ.
24 Nov 2014 19:00 - 24 Nov 2014 19:04
#654566
You're modifying a stock 1972 Z1 ? :blush: :blink: Ed
See:
motorcycles.smartcarguide.com/listing/48294932/
Last edit: 24 Nov 2014 19:04 by 650ed.
  • Yorkie
25 Nov 2014 12:54
#654616
Mine is one for the first 100 but it is missing a lot of the rare early parts like no-bar carbs, cast in vacuum port head and date coded switch gears so the purists would hate it. The bike has been restored with a lot of reproduction parts so its nowhere near as valuable as the high dollar ones you see on ebay. I plan on changing a few things to suit my taste but it will not be butchered.
'72 Z1
The following user(s) said Thank You: bluezbike
