1/4 turn throttle
  • Zapzuta
  • Zapzuta's Avatar Topic Author
1/4 turn throttle
09 Nov 2014 17:23
#653266
Has anyone found a 1/4 turn throttle for kz900 models?
Re: 1/4 turn throttle
09 Nov 2014 17:36
#653268
Do you plan on using it for racing or the street? I had one on my BSA and found it was far too touchy for the street. If I hit a bump I would sometimes find my front wheel pointing toward the sky! Ed
The following user(s) said Thank You: PLUMMEN
  • zukdave
  • zukdave's Avatar
10 Nov 2014 18:27
#653321
I run a Motion Pro 1/4 turn with my VM29's with just the pull cable.
Stock return spring is to strong so I found one at work that work's great.
Also had to add about 3/4" to the mount at the carb. end.
I can get a part number for the spring and you can go to your
local mower shop and get one.
As for street riding it took a little getting use to at first but it's normal
to me now so no big deal.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
11 Nov 2014 09:30
#653365
I mainly ride MX bikes so the extra twisting on my 900 to get WOT was a little getting used to.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
