Instrument Bracket Padding ???
  • kzdcw
  • kzdcw's Avatar Topic Author
  • 77' KZ1000A
19 Oct 2014 08:21
#651111
I'm at the point of cleaning up my gauges and wiring on my 77' Kz1000A. The instrument bracket has what appears as old dried up padding glued to it? Probably used to cushion or insulate the meters? What do you guys use for padding?
77' KZ1000A
Re: Instrument Bracket Padding ???
19 Oct 2014 08:41
#651113
I got some that were made for the Z1 (see image below) and they worked on my KZ650. They have been discontinued, but you usually can find them on eBay or at some online NOS parts houses. Ed
Attachment 00003a_2014-10-19.jpg not found
  • pete greek1
  • pete greek1's Avatar
19 Oct 2014 09:01
#651120
Duane, I don't know if they sell parts, but they did a great job restoring my gauges try calling & see if they have the parts you need
www.google.com/url?sa=t&rct=j&q=&esrc=s&...ayuGqzpoH-F7Btyzzqkw
Pete
  • kzdcw
  • 77' KZ1000A
19 Oct 2014 09:17
#651122
Pete, I'll shoot them an email Mon. I would think if a guy wants to be creative, you could find some rubberized padding of some sort and cut and glue to fit?
Also, either one of you know if the ( 4 ) rubber light bulb sockets for the instruments are available individually. Mine are pretty bad shape and gone. Don't know how well they would hold in the instruments? They were a bugger to get out and unfortunately crumbled in removal. To bad I couldn't use some sort of rubberized sealant to mod and bond to them?
The Instrument harness works just fine, just have taken everything apart to clean and inspect.
Installed a charged battery in my bike and found that most of all the electrical work. Was happy about that. Only the rear brake switch had a short that it was keeping the rear stop on. Just unplugged it and that was the culprit. It was broken prior at the mount, wear trying to repair it. Cheaper to purchase a new one.
Anyone know if Brian at KZ10006 is around? Been trying to get a hold of him for parts. Hope he's okay.
77' KZ1000A
  • kzdcw
  • 77' KZ1000A
19 Oct 2014 12:57
#651141
Ed. Partzilla Obsolete item. Ebay has all 4 Part #'s. Asking "Way" to much money for them. Time to go down to the local Hobby Craft store and be creative.
77' KZ1000A
  • JR
  • JR's Avatar
19 Oct 2014 13:31 - 19 Oct 2014 13:32
#651143
I have cut pieces from a mud flap for a pickup truck for something similar. .... of cut from a rubber sanding block when I needed something thicker.
Last edit: 19 Oct 2014 13:32 by JR.
  • kzdcw
  • 77' KZ1000A
19 Oct 2014 15:37
#651156
JR Not a bad idea. I was looking at a black sponge paint brush. May take a run down to Home Depot tomorrow as well.
77' KZ1000A
  • kzdcw
  • 77' KZ1000A
19 Oct 2014 16:48
#651164
Attachment T2eC16hHJGsFFMvUcmHqBRmn6czhow60_12.jpg not found
What do you guys think about this? 1/8" thick. Anyone have an idea how thick the stock dampers were?
77' KZ1000A
  • !Seymore
  • !Seymore's Avatar
  • Ride on...
19 Oct 2014 18:59
#651179
Use it... if it still wobbles, add another layer. Let us know how it works and how many layers you need...
C.
79' KZ650-D2 [fsm] (Max)
83' KZ750-F1 LTD [clymers] (Kay)
82' KZ1100-D1 Specter (another project)
78' KZ650-B2a (J&H, A Project)
91' KZ1000-P (P = parts)
19 Oct 2014 19:35
#651185
Mouse pad.
Good Fortune! :)
The following user(s) said Thank You: pete greek1, !Seymore
  • !Seymore
  • !Seymore's Avatar
  • Ride on...
19 Oct 2014 20:03
#651189
Oooooooooo.... I like that Patton!!!
C.
  • kzdcw
  • 77' KZ1000A
19 Oct 2014 20:21
#651191
Patton, Excellant idea too ! About an 1/8" thick.
77' KZ1000A
