Z1 900 -76 Caliper and fork leg confusion
- Micke
18 Oct 2014 13:01
Hi!
Got a Z1 900 -76 A4 "in a box". It's been dissasembled long time ago and now am I tryin to get it together. It's goin pretty well but now I hit something weird when working with the front break system (twin discs).
The calipers doesn't fit the bolt holes on the lower fork leg. The center distance between the holes on the caliper is 74 mm but it's only 54 mm between the bolt holes on the fork leg :ohmy:
I guess either the fork leg or the caliper break kit is from another bike model. Could someone give a hint on what is actually right for this model. Also advise on easiest way forward - replace break kit or fork legs woud be great.
Cheers
/Mikael, Sweden
Cheers
/Mikael, Sweden
Re: Z1 900 -76 Caliper and fork leg confusion
18 Oct 2014 13:44
The forks are from a different model. The Z900-A4 forks did not have reflectors. Ed
Attachment 00003a_2014-10-18.jpg not found
The following user(s) said Thank You: Micke
- floivanus
18 Oct 2014 14:52 - 18 Oct 2014 15:04
76 is a kz900, or z900, 75 is the last year of the z1; and parts are different, Im guessing later ltd brakes.
And 73-75 z1 forks, either gotta buy the z1 dual disc setup ($$$$) or the kz900/1000 stuff (cheap and correct). You also have a kz900/1000 fromt wheel and rotors
Past; 78 kz1000, 83 kz550
Andrew
Andrew
Last edit: 18 Oct 2014 15:04 by floivanus.
- PLUMMEN
18 Oct 2014 15:54
Calipers appear to be 76-77 900/1000 style along with wheel and axle,calipers and rotors might be from a 76 900 ltd also since they aren't drilled and still have steel/rubber lines.
Forks are z1 or early h series 2 smoker parts.
- pete greek1
18 Oct 2014 17:25
Looks like 73-75 fork bottoms, & they are not 76 LTD rotors, 76 LTD rotors were drilled
Pete
Pete
- PLUMMEN
18 Oct 2014 19:38
76 ltd rotors were not drilled.
The following user(s) said Thank You: pete greek1
- pete greek1
18 Oct 2014 21:16
I think you're right Plummen, , in fact, you are, right !! :blush: :blush:
- PLUMMEN
18 Oct 2014 21:30
I think it may of actually been 79 before the ltds started getting drilled rotors.
- Micke
19 Oct 2014 14:44
Great! Thanks for all comments! Guess I need to find a set of forks. Really want to keep thos twin discs.
Cheers
/Mikael
Cheers
/Mikael
- pete greek1
19 Oct 2014 14:55
I believe any KZ 1000 forks from 76-80 should be the same
Pete
Pete
The following user(s) said Thank You: PLUMMEN
- etbike3135
19 Oct 2014 15:02
PM me if you want to trade a set of fork legs for your. Just the bottoms not the tubes. I have several sets that are polished and nice.
1973 Kawasaki Z1
18 years in dragbikes
- pete greek1
19 Oct 2014 15:12
Tom, check your P.M.
Pete
Pete
