Softail to Hardtail
- aarb77
Softail to Hardtail
07 Oct 2014 17:58 - 07 Oct 2014 18:13
I have a 82 Kawasaki kz550 LTD that I will be lowering this winter and needed some pointers on safely doing this. My intention is to take off the rear shocks and add a solid bar to lower it as far as possible. I have included a picture for a example of what I am trying to accomplish. Concerns are thickness of steel and bushing housing. By bushing housing I am not sure if the hole bar should be solid or if it's structurally sound to just weld on the housings. Any help will be appreciated.
RB
Last edit: 07 Oct 2014 18:13 by aarb77.
Re: Softail to Hardtail
07 Oct 2014 18:18
Do you understand that the changes you plan not only will make the bike uncomfortable to ride but will also make it handle like a school bus which will increase your risks should you ever decide to ride it on a curvy road? Ed
- floivanus
07 Oct 2014 18:41
By curvy road ed means any kind of curve, angle or gentle angle with a bump at all.
Normal swing arm set up; hit bump, shocks compress tire stays on roads.
Ridgid; hit the same bump, tire defirms slightly, back end bounces tire loses contact, has chance to get squirly on you, may lead to some wacky fun
Past; 78 kz1000, 83 kz550
Andrew
Andrew
- aarb77
- Grumpy Ole Artist
- Eschew Obfuscation!
08 Oct 2014 07:21
DEFINITELY!!!! Your kidneys will thank you! LOL!
1978 KZ650 B2
Former rides...1976 CB360T, 1985 Shadow 700, 1985 GPZ750Turbo
- floivanus
08 Oct 2014 09:15
What are you looking to gain from lowering the bike? You can get a lot of room from other options.
Andrew
Andrew
- aarb77
Re: Re:Softail to Hardtail
09 Oct 2014 14:30
I just want the cleaner look without the shocks
RB
- aarb77
- aarb77
Re: Re:Re: Softail to Hardtail
09 Oct 2014 14:42 - 09 Oct 2014 14:42
This is what I'm modeling mine after
RB
Last edit: 09 Oct 2014 14:42 by aarb77.
09 Oct 2014 15:11
A mono shock conversion might be the best compromise. There are a couple of threads on the subject.
