z1f-27235 Frame
- Jeremy28c
z1f-27235 Frame
06 Oct 2014 17:04
I got this rolling frame and it looks like its a 1974 kz900 frame? The rotor date seems to be 1973. Im I right about this frame id.? And if so, I found a 1980 kz1000 mk2 engine locally and thought it would fit but I might have to modify the motor mounts. Any help would be great.
- kz10006
Re: z1f-27235 Frame
06 Oct 2014 17:31
Yo u dont have to modify the motor mounts it bolts up the same but the stator connections and ignition wires will have to be changed.
The following user(s) said Thank You: PLUMMEN
- Jeremy28c
- floivanus
Re: z1f-27235 Frame
06 Oct 2014 18:04
74 Z1, not a kz900. But yes the year is correct.
1973-75 are z1
1976 is a kz900
1977-1980 is kz1000
1973-75 are z1
1976 is a kz900
1977-1980 is kz1000
Past; 78 kz1000, 83 kz550
Andrew
Andrew
