tire size/ gs swingarm
- Silver Bullet 77
26 Sep 2014 21:09
I have a 77kz1000 with a 81 gs1100 swingarm and an aftermarket 18in wheel that I believe to be 4.25in wide. Does anyone know if I can use a 150-70 tire, why should I or should I not go with the wider tire? Avon makes the tire in 130,140,or 150. Any help would be appreciated
- davido
Re: tire size/ gs swingarm
27 Sep 2014 01:54
If you measure from the centerline of your current tyre (or wheel rim) , with all the spacers etc in place, to the chain,that should give you an idea of how far you can go with a fatter tyre.
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
27 Sep 2014 07:09
A 150 should fit fine inside that swingarm. Be sure to check tire to chain clearance though, and chain line.
