Replacing front Master cylinder
  • Witchwerx
  • Witchwerx's Avatar Topic Author
24 Sep 2014 15:15
#648654
I used the search function but came up empty handed. Sorry if this has been discussed before. Links to topics, if so, would be appreciated. I need to completely replace the front master cylinder on my 82 KZ 750 ltd.. I have looked on ebay, Amazon, as well as Dime City Cycles and a few others, but I unsure of the quality. I not wanting to put a lot of into this. Are the cheap Chinese master cylinders worth it? Any advice would be appreciated. I know I could go with a used factory one, but the quality is always suspect. I would rather go brand new since the entire brake system has been replaced with new parts. Everyone here always gives good advice so I am reaching out to the community. Thank you all in advance. If anyone's following, I still haven't been able to get the fork caps off either. :/
Re: Replacing front Master cylinder
24 Sep 2014 15:49 - 25 Sep 2014 08:02
#648657
I would not bet my life on a cheap Chinese master cylinder.
When removing the fork caps be sure to loosen the upper triple tree fork clamps first. Ed
Last edit: 25 Sep 2014 08:02 by 650ed.
  • Witchwerx
24 Sep 2014 16:00
#648660
Yeah, had another thread on the caps. Taking it to a buddy of mine to see what he can do. All the tricks and nothing clicked....so to speak. That's my worry with the cheap MCs... They're cheap. I don't mind plunking down on a decent one but I cannot seem to find any...
  • kzdcw
  • kzdcw's Avatar
  • 77' KZ1000A
25 Sep 2014 07:34
#648747
I've used 2 of the "Chinese" Front master Cylinders and have 0 problems with either of them. One's been on my 79'CBX for at least 5 years and other on my 72' H2 3 years. Maybe I got some good ones?
77' KZ1000A
  • zero10
  • zero10's Avatar
25 Sep 2014 07:56
#648755
I keep reading about people installing these $30-$50 chinese master cylinders, and aside from the odd person reporting that they received a different sized master cylinder than the ordered, or that the cylinder was marked differently from what it actually was (i.e. 12mm marked as 5/8) they seem to be quite reliable (or else the people who have had them fail didn't get the chance to complain about it)
I thought I was going to have to replace the master cylinder on my 82 KZ750H but I managed to flush all the chunks out of it and the seals were still in good shape with no leakage so I got lucky. My plan was to order one of the cheap ones from EBay if it needed replacement.
  • pete greek1
  • pete greek1's Avatar
25 Sep 2014 10:11
#648773
No eBay APP ID and/or Cert ID defined in Kunena configurationI have had one of these on my LTD 1000 for about 8 trouble free years, so I bought one last year for my LTD 900
but havn't installed it yet, gonna see if the original is rebuildable , when I get around to it :unsure: :unsure:
Pete
  • Kapahulu
  • Kapahulu's Avatar
25 Sep 2014 11:10
#648780
No eBay APP ID and/or Cert ID defined in Kunena configurationI had one of those mc's from USA-Motorcycles and it worked fine but after a couple of years the exterior finish was shot.
Recently I ordered one of these master cylinders (single disc):
It was from a different vendor, same product though. This is the best master cylinder I've ever used for a classic bike! Connect this one, bleed the brakes and the lever is solid - way better than rebuilding an old master cylinder plus it looks very similar to the original.
When I received the box, I noted it had a David Silver Spares label on it. So I went to the David Silver website and ordered another one. Direct from David Silver Spares, the cost was about $70 including shipping. I found it by searching for CB400F parts.
Now if you're looking for a dual disc caliper, here's one on the Z1Parts website: www.z1parts.net/product/kawasaki-z1-900-...r-assembly-43015-032
David Silver might also have them. Maybe you can look for a Gold Wing master cylinder or some other vintage Honda that had dual discs.
2strokeworld.com
  • Witchwerx
27 Sep 2014 08:42
#648942
I found a decent used one online and purchased it. If that doesn't work out, I'll grab a cheap one and run it through some paces hard (rear brake is excellent) So I can be sure. Thank again for all the help riders!
