Brake Pedal Spring Install ???
- kzdcw
- 77' KZ1000A
20 Sep 2014 08:27
77' KZ1000A Brake Pedal Spring. Is there an way to "Help" assist installing the brake pedal spring? I have it orientated correctly around the brake pedal ( one end of the spring underneath the pedal ) and frame ( the opposite end of the spring hooked over the frame above the pedal pivot ). I just can't get the spring to hook ! Fighting the tension of the spring ! What have you guys found that helps ?
77' KZ1000A
- steell
Re: Brake Pedal Spring Install ???
20 Sep 2014 18:23
I hook both ends of the spring, then install the pedal.
The following user(s) said Thank You: bluezbike
- PLUMMEN
20 Sep 2014 20:23
Be rally careful installing it,I broke my right ear trying to keep from scratching the chrome on my turbo bikes frame,the meat tenderizer part of brake pedal did its best to imbed itself in my skull! :sick: :blink:
- kzdcw
- 77' KZ1000A
20 Sep 2014 20:40
Steell, can you show me the steps how? I'm not sure how you hook both ends of the spring since one side of it sits underneath the brake pedal to put tension against it. The other end of the spring does hook to the frame. There's got to be an easier way, especially when it was assembled in the production plant?
Keep the ideas coming, I'm open to them all.
77' KZ1000A
21 Sep 2014 08:10 - 25 Sep 2014 19:56
Maybe you could make a jig?
I took apart a gas blower once & had to fabricate a jig to get the big pull start spring back in place. The jig was a couple of nails & a wood board, which made the job super simple.
Last edit: 25 Sep 2014 19:56 by martin_csr.
- LineArtist
21 Sep 2014 09:23 - 21 Sep 2014 09:30kzdcw wrote: 77' KZ1000A Brake Pedal Spring. Is there an way to "Help" assist installing the brake pedal spring? I have it orientated correctly around the brake pedal ( one end of the spring underneath the pedal ) and frame ( the opposite end of the spring hooked over the frame above the pedal pivot ). I just can't get the spring to hook ! Fighting the tension of the spring ! What have you guys found that helps ?
Is it this spring? (or please post a picture). Actually photos of where it goes on the bike would be helpful because of clearances, etc. Springs on anything are a major pain, let's figure out the easy way to get this back in there. I'll take a look on my bike, something tells me most of the KZ rear brake pedals are the same.
Attachment KGrHqNHJ8E-FObdf33BPiMqQlQ60_35.jpg not found
Attachment 3562712_130517_072922_7455.png not found
'79 KZ650B3 (stock)
'79 KZ650B3 (parts bike)
'06 HD 883R
'06 HD 883R
Last edit: 21 Sep 2014 09:30 by LineArtist.
- kzdcw
- 77' KZ1000A
21 Sep 2014 10:20
LineArtist, This is the spring you have pictured as well as the illustration. The left side of the pictured spring with the square hook or end, hooks on the frame. The right side of the spring ( curved end ) pictured goes underneath the brake pedal to hold it up. So if you have a "better" way to install it, I'm all ears !
77' KZ1000A
- LineArtist
21 Sep 2014 11:18
Can you rotate the brake pedal 45or90or180 degrees to put tension on the spring, Set it up and then rotate the pedal arm into position and bolt it all together? I'm not sure it will clear the exhaust or anything else. If not you may need to pull the brake arm out just enough to get it to clear without stretching the spring (too much). Haven't looked at my bike today, but that's my initial suggestion.
'79 KZ650B3 (stock)
'06 HD 883R
'06 HD 883R
- kzdcw
- 77' KZ1000A
21 Sep 2014 11:51
I have the bike sitting on a stand and the exhaust is pulled off, so shouldn't have to many obstacles
77' KZ1000A
- PLUMMEN
21 Sep 2014 14:03That's how I was doing it when I got clocked. :sick:LineArtist wrote: Can you rotate the brake pedal 45or90or180 degrees to put tension on the spring, Set it up and then rotate the pedal arm into position and bolt it all together? I'm not sure it will clear the exhaust or anything else. If not you may need to pull the brake arm out just enough to get it to clear without stretching the spring (too much). Haven't looked at my bike today, but that's my initial suggestion.
The following user(s) said Thank You: pete greek1
- pete greek1
21 Sep 2014 14:35
kzdcw, don't forget ta wear yer Helmet , :laugh: :laugh: :laugh:
Pete
Pete
The following user(s) said Thank You: PLUMMEN
- kzdcw
- 77' KZ1000A
21 Sep 2014 16:53
Words of encouragement :ohmy: But I will conquer and Thank You to the ones that provided a better insight. At least it gave me a better approach to tackle the job.
77' KZ1000A
