Brake caliper fitting?
  • Markovich
  • Markovich's Avatar Topic Author
11 Sep 2014 20:10
#647186
Hi all, so I have seen where there is a lot of discussion with regard to swapping brake calipers out on our old KZ's to upgrade braking. I was curious how many options there were available that would not require additional bracket manufacturing? Anyone know what the direct swaps are? Thanks, Keith
1990 KZ1000P, 72k miles, 10 years in storage, new, bars, tires, chain and sprockets, seat, carbs cleaned, police equipement removed.
  • 9er rider
  • 9er rider's Avatar
  • Keep a cool tool
Re: Brake caliper fitting?
11 Sep 2014 21:06 - 11 Sep 2014 21:10
#647190
Im putting twin calipers off 78 z1R on my 76 kz but Im not positive about a 1000p
Last edit: 11 Sep 2014 21:10 by 9er rider.
  • StreetfighterKz
  • StreetfighterKz's Avatar
12 Sep 2014 04:53 - 12 Sep 2014 04:53
#647213
I think the only different calipers that are a 100% bolt on are the Gpz750/1100 units. Everything else is going to need an adapter from what I've seen.
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
Last edit: 12 Sep 2014 04:53 by StreetfighterKz.
The following user(s) said Thank You: Markovich
  • Kapahulu
  • Kapahulu's Avatar
12 Sep 2014 05:25
#647216
For Kawi H1 and H2's, the EX250 and EX500 caliper (they're the same) is a popular and inexpensive replacement. It only takes a small metal adaptor plate, a 10 mm x 1.25 tap and a 10 x 1.25 bolt to fit. Then a new brake line of course.
I'm not sure if the adapter will also work for KZ's. Another triple/KZ owner may be able to provide more info. Here's a link: kawtriple.com/mraxl/caliper/conversions.htm
2strokeworld.com
  • Markovich
12 Sep 2014 21:06
#647321
I knew you guys would have the answer! Thanks for the info. Keith
