Steering Lock Set Screw???
  • kzdcw
  • kzdcw's Avatar Topic Author
  • 77' KZ1000A
07 Sep 2014 21:08
#646648
Had to drill out the set screw for the steering lock on my 77' KZ1000A. Screw was frozen. Does anyone know what size set screw this is? Want to get a tap and clean the threads.
77' KZ1000A
  • kzdcw
  • 77' KZ1000A
Re: Steering Lock Set Screw???
08 Sep 2014 14:50
#646734
Nobody has an idea to what size this set screw is :unsure: :unsure: I'll try to get some metric taps probably 6mm or less and see what I come up with.
77' KZ1000A
08 Sep 2014 16:30
#646744
For some odd reason the Kawasaki.com diagram calls that set screw a "Screw,Seat Lock" but as you can see in the diagram is is used in the steering lock. It is no longer available from Kawasaki, but you can get a bag of 5 from www.nwvintagecycleparts.com/search-resul...q=92014-016&st=spart . Ed
Attachment 00003a_2014-09-08.jpg not found
  • kzdcw
  • 77' KZ1000A
08 Sep 2014 18:54
#646767
Thank you for your response. I saw them on the ebay as all. But I believe it's not rocket science to find a set screw that will fit. It looks to me a 6mm tap. I just thought someone else had ran into this dilemma before and replaced the screw. ACE has a great selection of metric fasteners and should be able to find on there for little money.
77' KZ1000A
08 Sep 2014 19:44
#646773
It's unfortunate that the diagram doesn't show the size of the screw. Usually the diagrams do for regular fasteners, but not in this case. You probably can buy a couple different size screws for less than a buck each at a hardware store and see which one fits, and you can return the ones that don't fit. Ed
  • kzdcw
  • 77' KZ1000A
08 Sep 2014 19:52
#646776
That's what I have in mind Ed. When I find the right size, I'll report back so everyone can have the same info.
77' KZ1000A
  • kzdcw
  • 77' KZ1000A
11 Sep 2014 17:51
#647175
For anyone who wants to know, the seat lock screw or set screw for the fork lock is :
5mm .80 Pitch 1/4" in length
ACE Hardware 60 cents
77' KZ1000A
