Front Fender Help (on/off road KZ900)
- K.D. HART
05 Sep 2014 15:57
I have been putting this bike together. It's a hodgepodge of mismatched parts. I have some Shinko 244 dirt bike tires, 365mm eye to clevis shocks and 630 O ring chain ordered for it, but they haven't arrived yet.
It has a police front end and a 18 inch KZ1300 front wheel.
I want to get a front fender for it, but what something a little smaller than standard. I was thinking a CSR or GPZ front fender might work. Anyone have any ideas or suggestions??? Any help would be great.
kzrider.com/forum/11-projects/594694-dir...to-kz1000-now#638488
kzrider.com/forum/11-projects/591120-i-f...rbo-drag-bike#606286
kzrider.com/forum/11-projects/589806-197...750-suspension-build
- floivanus
Re: Front Fender Help (on/off road KZ900)
05 Sep 2014 16:50
Are you using the police trees with the front end? I believe they are wider spaced than the older style ones, might be too wide to use ancsr fender, would look good tho
Past; 78 kz1000, 83 kz550
Andrew
Andrew
- Mcdroid
- Gone Kwackers
05 Sep 2014 16:53floivanus wrote: Are you using the police trees with the front end? I believe they are wider spaced than the older style ones, might be too wide to use ancsr fender, would look good tho
+1...consider using a KZ1300 fender and spacers...cut the 1300 fender down?
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- kzdcw
- 77' KZ1000A
05 Sep 2014 16:55
On my 72' H2 which had a stock 19" front wheel. I converted to an 18" and used the front fender off a Kawasaki S3 400cc triple which has a 18" front. Worked perfectly. Have one on ebay right now for $20.00.
77' KZ1000A
- HBKwaka
05 Sep 2014 18:29
www.airtech-streamlining.com/kawiz/Z11973-80.htm
H2R4M
Kawasaki H2R Front fender
This is a wider version of the H2R4 above, designed for the wider KZ1000 Police front end. Width 5".
H2R4M
- K.D. HART
05 Sep 2014 18:59 - 05 Sep 2014 19:05Yes, 1979 1000C triple trees and 1982 1000P front forks.floivanus wrote: Are you using the police trees with the front end? I believe they are wider spaced than the older style ones, might be too wide to use ancsr fender, would look good tho
Last edit: 05 Sep 2014 19:05 by K.D. HART.
- K.D. HART
05 Sep 2014 19:02 - 05 Sep 2014 19:06HBKwaka wrote: www.airtech-streamlining.com/kawiz/Z11973-80.htm
H2R4M
Damn, that might be perfect. Thank you sir!
Last edit: 05 Sep 2014 19:06 by K.D. HART.
