difference between Z1 900 rear wheel & H2?
- Z1900motoguy
02 Sep 2014 14:37
is the any difference betewwn a Z1 900 Rear wheel and an H2? the only thing I can see is the H2 Brake backing plate does not have a wear indicator boss... any one know of any other differences?
Re: difference between Z1 900 rear wheel & H2?
02 Sep 2014 14:59 - 02 Sep 2014 15:02
Lots of good info on kawasaki.com, including parts diagrams, part names, part numbers, models sharing same part, availability, etc. Here's a link for help with navigating the site and finding information.
www.kzrider.com/forum/13-bike-related/37...imitstart=0&start=20
However, if the only difference is the wear indicator, they won't show as being the same part, and will have different part numbers.
Last edit: 02 Sep 2014 15:02 by Patton.
The following user(s) said Thank You: Z1900motoguy
- z1kzonly
02 Sep 2014 16:10No operating difference. You can use it. It is cleaner looking!Z1900motoguy wrote: is the any difference betewwn a Z1 900 Rear wheel and an H2? the only thing I can see is the H2 Brake backing plate does not have a wear indicator boss... any one know of any other differences?
And it ads $$ to it if you sell it on ebay! The early Z1 used it! not painted black, like the H2. I wish I had one again!
Can be used for a Z1 restoration or a H2 application if painted black.
Plus the bolt holding the cam lever was backwards on Z1's.
If you can get one, take it!
- Z1900motoguy
02 Sep 2014 16:15
was there any noticeable difference in the early Z1 900 Rear hub, as I bought a parts lot from a guy with alot of early Z1 parts, I was windering if the early Z1 900 (72 built ones used this brake, as it is the same as my 72 H2 brake, thats why I asked the question, in the parts lot was a regisration for Z1F-00047 so I am assuming this brake came off it, I also have a head with the syncing holes in the head instead of in the manifolds, and a set of ribless carbs.
- z1kzonly
02 Sep 2014 16:22
Lucky you! Oinkjohnson's ebay shill Gang sold ribless carbs for $1800 1 1/2 years ago. I sold an early head with the nipples in the head , first VIN's# 2,200 for $430 to Austaralia. Good money items if your selling! Early carbs sucked! 2nd version sucked a little less, 3rd version a little more less! Only people wanting original restoration want the stuff.
You selling the items???
- z1kzonly
02 Sep 2014 16:26
Back to the rear wheel. No, there is no difference. Except for the date code on the rim. Early 72-73 date codes are coveted.
If they are clean, and don't need a re-chrome.
Show us some pictures.
- Z1900motoguy
02 Sep 2014 21:58
they are laced to campagnolo ( akront style) Aluminum rims unfortunately.
- FaultedGeologist
- The truly educated never graduate...
02 Sep 2014 23:36
Campagnolo, the. Italian bicycle company? As a cyclist and old bike builder, I must also request some pics!!!
Clint
1980 KZ750 LTD H4
FSMaunual: kz.bike-night.com/media/GPz750-full.pdf
Stock except for:
New chain and sprocket (530?).
Dynatek Ignition
Manual tensioner on the way.
Buy JIS screwdrivers.
1980 KZ750 LTD H4
Stock except for:
Dynatek Ignition
