Removing Stubborn Set Screw???
  • kzdcw
  • kzdcw's Avatar Topic Author
  • 77' KZ1000A
23 Aug 2014 21:36
#644956
On my 77' KZ1000A I'm trying to remove the small slotted set screw that holds the fork lock. It's frozen and have sprayed it several times with PB blaster to help loosen but not working. I don't have small enough impact driver bit to fit it. Any suggestions besides drilling the set screw? Is there a narrower impact driver bit I could find?
77' KZ1000A
  • PLUMMEN
  • PLUMMEN's Avatar
Re: Removing Stubborn Set Screw???
23 Aug 2014 22:22
#644958
Maybe try heating the area around the screw with a propane torch,then cool it down with the pb blaster. ;)
  • !Seymore
  • !Seymore's Avatar
  • Ride on...
24 Aug 2014 00:40
#644966
If you have a spare bit, why not grind it to what you need?
C.
79' KZ650-D2 [fsm] (Max)
83' KZ750-F1 LTD [clymers] (Kay)
82' KZ1100-D1 Specter (another project)
78' KZ650-B2a (J&H, A Project)
91' KZ1000-P (P = parts)
  • kzdcw
  • 77' KZ1000A
24 Aug 2014 02:52
#644968
Don't have a spare bit. Does someone know a source where you can purchase narrower or smaller ones? Think I'll go down to Harbor Freight and purchase a propane torch.
77' KZ1000A
  • martin_csr
  • martin_csr's Avatar
24 Aug 2014 07:03 - 24 Aug 2014 07:04
#644974
Kano Kroil is supposed to be a really good penetrant.
Liquid Wrench penetrating spray lubricant is also good --- it did better than the pbb in a couple of tests. pbblaster has a catchier name & wam-pow label, though. :)
Last edit: 24 Aug 2014 07:04 by martin_csr.
  • bluezbike
  • bluezbike's Avatar
24 Aug 2014 09:30
#644979
Red's outstrips (pun intended) every other bolt loosener out there......mix 50% Auto Trans Fluid and %50 Acetone and apply.....and Hey Presto :silly:
79 KZ 1000 LTD
  • kzdcw
  • 77' KZ1000A
24 Aug 2014 09:59
#644983
I read that recently on the internet seemingly to have great results. Worth a try and certainly a lot cheaper. Thanks !!!
77' KZ1000A
