Plugging (air-ride) fork shafts
- daveo
18 Aug 2014 09:57
Since replacing the air-ride fork suspension with Progressive springs, I've been wanting to remove the air-share apparatus from them, but will encounter a slight problem by doing so.
The holes currently covered by the o-ringed flanges will need to be plugged, to prevent fork-oil from escaping. I'm thinking of inserting 4mm set-screws, after tapping out the holes just deep enough to provide solid stops for the threads, while positioning the heads just below the surface.
Anyone have a better idea, other than replacing the shafts or leaving them alone?
1982 KZ1100-A2/1170 sleeper 😀
- PLUMMEN
Re: Plugging (air-ride) fork shafts
18 Aug 2014 12:10
Seems like the easiest way to fix them to me.
- daveo
18 Aug 2014 23:58PLUMMEN wrote: Seems like the easiest way to fix them to me.
It was fairly simple, but I didn't gauge the depth of tapping by-hand very well. The 6mm long set-screws were about 30% too long, so the excess was ground off, otherwise the tips touched the spring coils in the tubes.
The whole process took about two hours, and it really cleaned-up and uncluttered the forks.
Its my opinion that the ride with Progressive front springs (and rear shocks), is like having a whole-different bike...far-better than the old, stock air-ride system.
The following user(s) said Thank You: PLUMMEN
- Puffin
19 Aug 2014 02:36
Daveo i have also done this on my 1100. I used stainless grub screws loctited in place. It does indeed tidy up the front end especially if you loose some of the other clutter at the same time :woohoo:
KZ1000 J Long Term Owner
KZ1100
KZ1100 Spectre project
KZ1100
- daveo
19 Aug 2014 08:03Puffin wrote: Daveo i have also done this on my 1100. I used stainless grub screws loctited in place. It does indeed tidy up the front end especially if you loose some of the other clutter at the same time :woohoo:
I used silicone on the threads, thinking that would work good to seal them.
Which Loctite did you use, and how well did it work?
- Puffin
20 Aug 2014 00:41daveo wrote:Puffin wrote: Daveo i have also done this on my 1100. I used stainless grub screws loctited in place. It does indeed tidy up the front end especially if you loose some of the other clutter at the same time :woohoo:
Im sure the silicone will be fine
KZ1100
KZ1100
