Fork cap removal...grr
Re: Fork cap removal...grr
14 Aug 2014 10:56
#643927
Two suggestions
- soak it with Kroil for 2 or 3 days. That stuff has saved my butt more than once on stuck fasteners. If you need help finding Kroil - ask.
- remove that top bolt of the triple tree clamp all the way
  • !Seymore
  • !Seymore's Avatar
  • Ride on...
14 Aug 2014 11:10 - 14 Aug 2014 11:12
#643931
I'll add to what Ed's posted...
I usually will loosen all the bolts that hold the fork tube, slide the tube up an inch and retighten the bolts again... something firm to hold the tube... and try again. Can't be gripping that tube at the top, while trying to loosen the cap.
update: Ahhhhhhhh... I see this has already been suggested, but the PIC shown does not reflect the suggestion.
C.
79' KZ650-D2 [fsm] (Max)
83' KZ750-F1 LTD [clymers] (Kay)
82' KZ1100-D1 Specter (another project)
78' KZ650-B2a (J&H, A Project)
91' KZ1000-P (P = parts)
Last edit: 14 Aug 2014 11:12 by !Seymore.
  • Witchwerx
  • Witchwerx's Avatar Topic Author
14 Aug 2014 11:28
#643933
Despite the picture, the top clamps are very loose, bolts backed a 1/4 inch past the clamp and I even opened the clamp slightly with a flat edge. The bottom clamp is all that's holding it.
  • !Seymore
  • !Seymore's Avatar
  • Ride on...
14 Aug 2014 12:01
#643940
OK... Well, using a penetrating oil may be your best bet then. Something thin that will get into all the nooks-n-crannies and let it soak in for a few days... with multiple applications over this time frame.
Good luck and keep us posted...
C.
  • Witchwerx
14 Aug 2014 12:09
#643944
Will do. All I have is PB Blaster. I've heard of Kroil. Available anywhere or online only? Or any penetrates recommended over PB?
  • !Seymore
  • !Seymore's Avatar
  • Ride on...
14 Aug 2014 12:17
#643946
Well, if you want to try something new, I make my own with ATF and nail polish remover (acetone), 50-50. It's really thin, so many applications will be needed.
C.
The following user(s) said Thank You: Witchwerx
14 Aug 2014 12:21
#643949
!Seymore wrote: Well, if you want to try something new, I make my own with ATF and nail polish remover (acetone), 50-50. It's really thin, so many applications will be needed.
I have read that that mixture works great. Ed
  • Witchwerx
14 Aug 2014 12:57
#643957
I have a lot of both. Gonna try it. I'll use the old nitrile glove trick as a container. Clip a finger tip off, stretch it over the fork, fill the glove and tie it off. I'll give it a few days to work It's way in and give you the results. :)
  • martin_csr
  • martin_csr's Avatar
14 Aug 2014 13:12
#643958
LiquidWrench penetrating spray lubricant is a good product --- it did better than PB Blaster in a test & I've used it successfully numerous times. Let the penetrant sit overnight.
Try applying heat w a propane torch. That's what I did. You could alternate between the heat & penetrant. Heat, let it cool, penetrant. heat, let it cool, penetrant.etc. etc. etc.
A 22mm wrench or crescent wrench should fit the fork cap. A pipe fitted over the handle will give some leverage. I used a spare triple tree as a clamping device.
  • !Seymore
  • !Seymore's Avatar
  • Ride on...
14 Aug 2014 13:14 - 14 Aug 2014 13:14
#643960
Witchwerx wrote: I have a lot of both. Gonna try it. I'll use the old nitrile glove trick as a container. Clip a finger tip off, stretch it over the fork, fill the glove and tie it off. I'll give it a few days to work It's way in and give you the results. :)
C.
Last edit: 14 Aug 2014 13:14 by !Seymore.
15 Aug 2014 04:42
#644023
Reportedly, Nitrile has poor resistance to acetone, with a four minute breakthrough time.
Good Fortune! :)
  • Witchwerx
27 Sep 2014 08:45
#648945
At this point I'm going to go at it with a torch and a breaker bar again. I have a friend who's an old marine mechanic and he's confident we can get it off. As promised, once the caps are loose, I'll do a full write up with pics on disassembly and reassembly.
