How does one actually?
- jsnabbs
- 1981 kawiKZ440
01 Aug 2014 12:05
Remove and replace the disk rotor on a KZ440?
It seems to be pressed on, how do i take it off and replace?
TIME TO TRADE IN THE PEDALS FOR SOME POWER
Re: How does one actually?
01 Aug 2014 12:43 - 01 Aug 2014 12:46
No eBay APP ID and/or Cert ID defined in Kunena configurationCould be wrong, but thinking the rotor assembly is permanently combined as a single component and not designed to be taken apart.
Part Number 41080-1027 and relativly expensive as a new part, being $508.74 at Partzilla.
www.partzilla.com/parts/detail/kawasaki/KP-41080-1027.html
Perhaps a resort to ebay
Last edit: 01 Aug 2014 12:46 by Patton.
01 Aug 2014 13:39
4 bolts hold it to the wheel. Ed
- jsnabbs
- 1981 kawiKZ440
01 Aug 2014 18:52
well i ordered a new disk and this is what turned up
Attachment IMG_0436_2014-08-01.jpg not found
01 Aug 2014 19:04
- jsnabbs
- 1981 kawiKZ440
01 Aug 2014 19:17
Yes so it has 7 drilled holes, where it looks like the studs should attatch, so how does this work with "4 bolts hold it to the wheel"?
01 Aug 2014 19:22 - 01 Aug 2014 19:32
[strike]I for one have never seen a topic about mating a 7-bolt disk to a 4-bolt hub. For starters I guess I would remove the old disk & lay the new one on top to see if the holes line up. Maybe a machine shop can remove the old rivets & attach the new disk to the old 4-bolt plate?!?1?[/strike]
Edit: The 4-bolt disk has 8 rivets & the 7-bolt disk holes don't line up.
Last edit: 01 Aug 2014 19:32 by martin_csr.
01 Aug 2014 19:24jsnabbs wrote: Yes so it has 7 drilled holes, where it looks like the studs should attatch, so how does this work with "4 bolts hold it to the wheel"?
It doesn't. You bought the wrong part. Send it back and buy the correct part. Ed
- jsnabbs
- 1981 kawiKZ440
01 Aug 2014 19:30
I just notice that the ebay picture and a picture i have of my wheels +
has 8 holes, the disk i have has 7, so i guess thats off to a bad start.
i wanted to replace because my disk has some pretty big grooves
Attachment Rubber_2014-08-01.jpg not found
01 Aug 2014 19:34 - 01 Aug 2014 19:35Most used disks I've seen on eebbaayy have grooves. The stock disk from my 81 650 is grooved as are a couple of used 7-bolt disks. Does the front brake work & is the thickness within spec?jsnabbs wrote: i wanted to replace because my disk has some pretty big grooves
Last edit: 01 Aug 2014 19:35 by martin_csr.
01 Aug 2014 20:57jsnabbs wrote: I just notice that the ebay picture and a picture i have of my wheels +
You are wrong. Count again! Your disk is held to the wheel with 4 bolts NOT 8. Forget 8 holes, they mean nothing. Those 8 are the RIVETS that permanently attach the disk to the carrier. You cannot separate the two and expect to re-attach another disk to the carrier. You need to buy the correct unit. The correct unit will have the carrier already permanently attached to the disk. They are one - not two units. They come together. You do not buy them separately. This is not difficult. It is extremely easy. Ed
The following user(s) said Thank You: jsnabbs
- jsnabbs
- 1981 kawiKZ440
02 Aug 2014 00:05martin_csr wrote:Most used disks I've seen on eebbaayy have grooves. The stock disk from my 81 650 is grooved as are a couple of used 7-bolt disks. Does the front brake work & is the thickness within spec?jsnabbs wrote: i wanted to replace because my disk has some pretty big grooves
when i took the bike for a test ride yes the brakes did work, when i took the brakes apart the pads were down to nothing.
I will send the rotor back, i got it new from ebay and it was advertised as for a KZ440C, which i now realize is wrong and will not work.
Now i will just try it with the new brake pads and see how that goes
thanks for the help guys
