How does one actually?
  • jsnabbs
  • jsnabbs's Avatar Topic Author
  • 1981 kawiKZ440
01 Aug 2014 12:05
#642332
Remove and replace the disk rotor on a KZ440?
It seems to be pressed on, how do i take it off and replace?
TIME TO TRADE IN THE PEDALS FOR SOME POWER
Re: How does one actually?
01 Aug 2014 12:43 - 01 Aug 2014 12:46
#642339
No eBay APP ID and/or Cert ID defined in Kunena configurationCould be wrong, but thinking the rotor assembly is permanently combined as a single component and not designed to be taken apart.
Part Number 41080-1027 and relativly expensive as a new part, being $508.74 at Partzilla.
www.partzilla.com/parts/detail/kawasaki/KP-41080-1027.html
Perhaps a resort to ebay :unsure:
Good Fortune! :)
Last edit: 01 Aug 2014 12:46 by Patton.
01 Aug 2014 13:39
#642349
4 bolts hold it to the wheel. Ed
  • jsnabbs
  • 1981 kawiKZ440
01 Aug 2014 18:52
#642393
well i ordered a new disk and this is what turned up
Attachment IMG_0436_2014-08-01.jpg not found
01 Aug 2014 19:04
#642396
Yes; we saw that picture a week ago at:
www.kzrider.com/forum/5-chassis/595033-disk-brake#641309
  • jsnabbs
  • 1981 kawiKZ440
01 Aug 2014 19:17
#642400
Yes so it has 7 drilled holes, where it looks like the studs should attatch, so how does this work with "4 bolts hold it to the wheel"?
  • martin_csr
  • martin_csr's Avatar
01 Aug 2014 19:22 - 01 Aug 2014 19:32
#642402
[strike]I for one have never seen a topic about mating a 7-bolt disk to a 4-bolt hub. For starters I guess I would remove the old disk & lay the new one on top to see if the holes line up. Maybe a machine shop can remove the old rivets & attach the new disk to the old 4-bolt plate?!?1?[/strike]
Edit: The 4-bolt disk has 8 rivets & the 7-bolt disk holes don't line up.
Last edit: 01 Aug 2014 19:32 by martin_csr.
01 Aug 2014 19:24
#642404
jsnabbs wrote: Yes so it has 7 drilled holes, where it looks like the studs should attatch, so how does this work with "4 bolts hold it to the wheel"?
It doesn't. You bought the wrong part. Send it back and buy the correct part. Ed
  • jsnabbs
  • 1981 kawiKZ440
01 Aug 2014 19:30
#642407
I just notice that the ebay picture and a picture i have of my wheels +
Attachment Rubber_2014-08-01.jpg not found
has 8 holes, the disk i have has 7, so i guess thats off to a bad start.
i wanted to replace because my disk has some pretty big grooves
  • martin_csr
01 Aug 2014 19:34 - 01 Aug 2014 19:35
#642410
jsnabbs wrote: i wanted to replace because my disk has some pretty big grooves
Most used disks I've seen on eebbaayy have grooves. The stock disk from my 81 650 is grooved as are a couple of used 7-bolt disks. Does the front brake work & is the thickness within spec?
Last edit: 01 Aug 2014 19:35 by martin_csr.
01 Aug 2014 20:57
#642419
jsnabbs wrote: I just notice that the ebay picture and a picture i have of my wheels +
You are wrong. Count again! Your disk is held to the wheel with 4 bolts NOT 8. Forget 8 holes, they mean nothing. Those 8 are the RIVETS that permanently attach the disk to the carrier. You cannot separate the two and expect to re-attach another disk to the carrier. You need to buy the correct unit. The correct unit will have the carrier already permanently attached to the disk. They are one - not two units. They come together. You do not buy them separately. This is not difficult. It is extremely easy. Ed
The following user(s) said Thank You: jsnabbs
  • jsnabbs
  • 1981 kawiKZ440
02 Aug 2014 00:05
#642430
when i took the bike for a test ride yes the brakes did work, when i took the brakes apart the pads were down to nothing.
I will send the rotor back, i got it new from ebay and it was advertised as for a KZ440C, which i now realize is wrong and will not work.
Now i will just try it with the new brake pads and see how that goes
thanks for the help guys
