KZ1100 Bevel/Final Drive
  • jbuck
  • jbuck's Avatar Topic Author
26 Jul 2014 10:43
#641494
Just tore into my final drive because I'm not sure its ever been serviced. A couple things look out of what to me.
First, the nut the spring sits on looks dented. How is this possible and do you think its OK to reassemble this way? See pics.
Second, it looks like the spring is just rubbing against the shaft (see pic). Is the spring supposed to be loose like this?
Any advice appreciated!
'83 KZ1100 LTD
  • Nebr_Rex
  • Nebr_Rex's Avatar
Re: KZ1100 Bevel/Final Drive
26 Jul 2014 13:35
#641515
Looks good to me.
This is the spare to my '79.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
  • jbuck
26 Jul 2014 14:30 - 26 Jul 2014 14:31
#641524
So the nut has been "punched" to keep it from coming loose?
The spring is quite worn on the forward end as well. Looks a little thin, but still plenty springy. I can't believe there isn't more than the top of the pinion nut keeping the spring in place. It just sits on the nut and presses against the flat part of the shaft, Correct?
Thanks for the advice!
'83 KZ1100 LTD
Last edit: 26 Jul 2014 14:31 by jbuck.
