GPZ 550 Wheels on KZ 750
- kawasaki750e
- slayer61
- KZR FLAG RELAY CARRIER #62
Re: GPZ 550 Wheels on KZ 750
23 Jul 2014 08:37
Consider looking at partzilla or Kawasaki.com and see if the axle sizes are the same on both models. What years are we talking about? If the axles are the same, you're off to a good start, then it's just a matter of finding/making spacers to align the sprocket, rotor and caliper! Easy Peasy!
- loudhvx
23 Jul 2014 09:42
Just FYI, there are 3 different types of GPZ550's, each with different wheels.
81 had 7-spoke.
82-83 had 5-spoke.
84-85 had a sort of 3-spoke design.
81 had 7-spoke.
82-83 had 5-spoke.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
24 Jul 2014 08:30
Look at the front diameter too. The early bikes used a 19" front, but moved to 18" in later years which would be more difficult to adapt.
- steell
24 Jul 2014 11:40
The easiest way to determine if there is a chance of fitting is to compare the front and rear wheel bearings, If both bikes use the same bearings then the axles are the same diameter, then all you need to worry about are spacers.
